Old 30-Jan-2019, 7:15 PM   #1
commoncents
antenna minnesnowta
need help with antenna selection in MN. zip 55372
http://www.tvfool.com/?option=com_wr...9038e96ed8c224
i have a traditional large attic antenna now that hasn't gotten reception. im not sure if its the antenna, wiring, or just that the attic isnt a good spot for any antenna. also tried an indoor antenna cabled right to TV and it didnt work either. it is a townhome so i do have limited options by association in rooftop for a traditional style.
i could prob get a way with the enclosed ufo type antennas rooftop, but not sure if they are rated very high or not.
commoncents is offline   Reply With Quote
Old 31-Jan-2019, 12:54 PM   #2
jrgagne99
Your signals look good and strong. Did you ever get solid reception from the attic antenna? Have trees grown up that are blocking the view now? I would think a simple rig like the C2V pointed NNE and mounted outside would get you all the major networks. The home owner's association can't prevent you from putting up such an antenna. When push comes to shove, the FCC laws are on your side.
Old 31-Jan-2019, 3:40 PM   #3
The rules are different when if comes to dwellings that are not individually owned such as condos, townhouses, apartments, and the like. One has to dig into the details before making any such assessment as OTARD protections are not the same for this type of residence. Unless the proposed mounting spot falls into the resident's "exclusive use" domain, the association does have to right to prohibit placing an antenna in that location. For roofs or other cooperatively owned parts of the structure, they also have that same right (and responsibility to the other owners) to restrict access to privately owned and installed external antennas. The devil, as they say, is in the details and we are not privy to those details.
Pretty much any small UHF/VHF combo that is mounted in a decent location would be expected to work well provided there are no errors or oversights in the setup. Usually, such issues are due to skipping or missing a part of the setup procedure like not putting the V set into "antenna" mode or not running the channel scan properly. I define a "decent location" as one where the signals actually have a chance to get to the antenna and are not blocked by buildings, construction materials, or trees that would be expected to impair or obstruct the signals from getting to the antenna. Avoid the "UFO" type antennas when all signals come from the same direction as they tend to be very susceptible to multi-path and there's no sense in sacrificing a measure of expected reliability when not necessary.
Our usual recommendation from our product line for TVFool plots like this, in the absence of full information, would be either a C2MAX or a C2V. No amp should be needed based on the provided plot.
