Old 20-Jan-2014, 7:04 PM   #1
Markey
HD antenna advice
Finally ready to cut the cord and looking for some feedback on antenna type and setup.
I plan to use the existing coaxial cable and use an outdoor antenna. Placement would be on the west side of my house approx. 10 feet above ground.
http://www.tvfool.com/?option=com_wr...5b94d0b3e4fcdc
Appreciate the help!
Markey is offline   Reply With Quote
Old 21-Jan-2014, 4:05 AM   #2
Consider the Antennacraft HD850 or CS290... Or the Channel Master CM3018 or CM5018. These are all channel antennas, which include coverage for WLFM on real CH-6 http://en.wikipedia.org/wiki/WLFM-LP
If you have no interest in WLFM, an RCA ANT-751R would offer the coverage for the remaining signals west of your location.
Old 21-Jan-2014, 9:05 AM   #3
Install a , www.antennacraft.net , HBU11K antenna Above The Peak Of The Roof.
Aim the HBU11K antenna at about 300 degree magnetic compass direction.
Old 22-Jan-2014, 2:19 AM   #4
Markey
Thanks guys, I appreciate the help. Surprising how affordable these antennas are. Now I just need to buy more coaxial and try not to pull a Clark W Griswold climbing on the roof.
Old 23-Jan-2014, 2:00 PM   #5
bytor
Considering how much one pays in Cable or Satellite bills annually setting up for OTA pays for itself most of the time in a couple of months.
bytor is offline   Reply With Quote
Old 24-Jan-2014, 2:30 AM   #6
Markey
True this is less than a 1 month payback which is a no brainer considering I never watch 90% of the junk on cable.
Now I am thinking this would be perfect for our camp in central pa, although considering the remoteness and the fact that we are in a valley is this a pipe dream to expect to pick up a few local channels?
http://www.tvfool.com/?option=com_wr...5b94df26152018
Old 24-Jan-2014, 6:23 PM   #7
At the camp site , looks like , WPSU-Tv Real UHF channel 15 PBS.
WHVL Real UHF channel 27 MyNetwork and America One.
Will be received.
W42DG , Real UHF channel 42 , NBC and Me-Tv.
Is very weak signal strength at , 12.1 NM(dB) and will most likely not be received reliably.
To see if more antenna height above ground will improve signal strength.
Please make and post 2 more Tvfool reports.
40 and 60 feet antenna height above ground.
Do not delete the first Tvfool report that has the antenna height 20 feet above ground.
