Old 6-Dec-2024, 2:36 PM   #1
smcquary
Antenna recommendations for Clearwater Fl
Looking for recommendations for Clearwater FL. 2 TVs running from a Tablo.
Here is my report.
http://www.tvfool.com/?option=com_wr...b0fe35236a6e2b
Thanks
Shannon
smcquary is offline   Reply With Quote
Old 8-Dec-2024, 11:39 PM   #2
smcquary
Specifically looking for antenna recommendations.
Thanks
Old 22-Dec-2024, 6:45 PM   #3
Here is my report.
Thanks
Shannon
Hello, Shannon. Thank you for the TVFool signal report.
Unfortunately, TVFool reports are no longer very accurate because their database is out of date.
I did an estimated report using the rabbitears.info Signal Search Map which gave this result
https://www.rabbitears.info/searchma...udy_id=1861492
Please doublecheck my estimate for 1788mom here:
Old 25-Dec-2024, 7:37 PM   #4
Thanks
Merry Christmas!
Your signal report looks a lot like my report:
I'm using a GE 29884 antenna indoors
https:www.amazon.com/GE-Outdoor-Supports-Included-Resistant/dp/B01MYMVPVX/ref=asc_df_B01MYMVPVX?th=1
and am able to receive down to RF 7 WTPC TBN:
It works a little better over the bed where there is less electrical noise (EMI) on VHF-High channels 7-13:
If it doesn't work for you indoors, add a preamp.
If it still doesn't work for you, the antenna must be mounted outside or in the attic if you don't have an aluminum foil thermal barrier in the roof.
And if that antenna still doesn't work for you, a larger antenna is needed:
https://www.amazon.com/Winegard-Plat...01DFTGR4/?th=1
Try to make an indoor antenna work first because you are in a high density lightning strike area. An outdoor antenna should be properly grounded.
