13-Sep-2017, 9:14 PM
#21
I have never been able to get WTAE and WPNT used to come in but doesn't now.
WPXI only comes in sometimes.
WWCP from Altoona is pretty reliable and my only source for ABC.
WJAC from Johnstown is clear but loses signal more often.
I shouldn't be getting Steubenville stations but they are some of my better ones
WWCP and WJAC are coming from the SE, but you say your antenna is aimed SW.
I don't mean to be insulting, but which end of the antenna in the photo above do you think is the front of the antenna that you aim at the transmitters, the end at the left or the end at the right?
Please look at the photo in the PM (Private Message) I sent to you and tell me if I have the right house.
13-Sep-2017, 9:32 PM
#22
No insult taken.
I'm not the sharpest knife in this drawer.
I have always pointed the narrow end towards the signal.
In the picture posted above, the right side is W or wSW
13-Sep-2017, 10:26 PM
#23
Also, if you look at the green lines in the picture you PMed, starting at the left.
The top left line is a faint green, then there are 2 solid green lines.
The second solid line is a close approximation to the direction my antenna is pointing
13-Sep-2017, 11:51 PM
#24
Originally Posted by blackstone
No insult taken.
Good. Thank you for the clarification.
14-Sep-2017, 12:15 AM
#25
That looks good to me. What confused me was there were no leaves on the trees across the road in the satellite view.
14-Sep-2017, 12:20 AM
#26
Hard to say when that image was taken
14-Sep-2017, 1:28 AM
#27
This is the image you said I could post, which shows the green signal lines:
14-Sep-2017, 1:36 AM
#28
For anyone who may be interested, there are 3 green lines on the left of the picture.
One faint at the top and 2 heavier.
Including the faint line, the 3rd line down is a close approximation to where my antenna is pointing.
Whatever direction that is
14-Sep-2017, 1:57 AM
#29
I tried different antenna heights, and it helps with some channels because of the rough terrain:
14-Sep-2017, 2:02 AM
#30
Thank you.
Not sure what it's telling me unless the hills block or diffuse the signal?
14-Sep-2017, 3:46 PM
#31
Yes, that is exactly what happens.
The tvfool software for a report doesn't know about the trees or other ground clutter; it uses changes in elevation along the signal path to predict what will happen to the signal on its way to your antenna.
14-Sep-2017, 4:31 PM
#32
Is there a solution or something I live with?
In years past, WPXI came in reliably.
Now, maybe 50% of the time.
Also, up until a week or so ago, WJAC (Johnstown) and WWCP (Altoona) were also pretty reliable.
I can move the antenna slightly southward a few degrees and pick them up.
However, I lose some other stations.
I want my cake and eat it, too.
Last night I did a scan and got 31 stations.
Not all of them displayed well due to pixilation, specifically, WJAC.
WWCP came in well
14-Sep-2017, 7:38 PM
#33
I think you need to move the antenna around a bit (left, right, higher, whatever) to try and find better spots for reception. As rabbit will tell you, the best spot for reception is not necessarily the most convenient or aesthetically pleasing. It's easier with two people. One to hold the antenna and one at the TV checking signal strength.
14-Sep-2017, 7:50 PM
#34
Thanks, jrgagne99.
The antenna has been in that exact spot for 60 years.
If it was good enough for my dad, it should be good enough for me.
Just kidding.
When I replaced the mast a year or so ago, I increased the height a few feet
14-Sep-2017, 8:31 PM
#35
Is there a solution or something I (can) live with?
Yes, but you will not like it.
The trees are growing.
Your antenna is very directional. If you aim it for the SW channels, the SE channels will be too weak. If you aim it for the SE channels, the SW channels will be too weak.
Of course, we all do.
You need a rotator (which you don't want) or two antennas, one for each direction.
But before you do that, you should try a preamp at the antenna, as suggested by jrgagne99 in post #2. A preamp at the antenna is much more effective than a booster down below.
How long is the coax from the antenna to the CM3414 in the basement?
Although I agree that a rotor will definitely improve my performance, I am concerned about the second TV.
That is my wife's and we don't, usually, watch the same things.
If your wife's favorite channels are all in the same direction, just make sure her TV is connected to the antenna for that direction. If your wife's channels are in two directions, it gets complicated. You will then need two coax lines to her TV and an A/B switch. An alternative would be to connect the second antenna to a separate tuner, with its output connected to the aux input of the TV.
If there is only one channel from the second antenna, then it could be combined into one coax with a custom (expensive) single channel inserter.
WWCP came in well
For best results, the antenna must be aimed at the transmitter; splitting the difference will not work for you.
14-Sep-2017, 8:54 PM
#36
Not arguing the point because I don't know but recent past results are different.
Just stating my personal experience.
I apologize and not trying to be obstinate.
Your antenna is very directional. If you aim it for the SW channels, the SE channels will be too weak. If you aim it for the SE channel, the SW channels will be too weak.
That is one of the many things that confuse me.
Until a week or two ago, these channels came in adequately 80+% of the time.
I have not adjusted the direction in several months.
I know a rotor will improve reception.
But, how do I get performance from the 2 separate TVs that want to watch different stations?
For example one wants to watch WJAC and the other WPGH?
Another point is where the heck is north?
Apparently it moves around here on Peach Hill.
Just got my new better compass and anxiously went outside to get a true bearing of which way my antenna is pointed.
North moves 30-45 degrees while I'm holding the compass.
My best guess is I'm pointing 230 or so but who knows?
14-Sep-2017, 9:34 PM
#37
I understand.
The change in reception could be for more than one reason. The antenna might not be doing as well as when it was new and the trees are growing higher.
There is no need for you to apologize. We understand that you want good reception on all TVs, but there is no easy fix for reception from two different directions at your location.
Many of your signals are weak, which requires an antenna with a lot of gain. But, a high gain antenna is VERY directional.
Trees like to grow taller in the summer. If the reception gets better after the leaves fall, it was the trees. If it doesn't get better, then it might be the antenna.
By making sure that each TV is connected to the right antenna for that TV.
WJAC NBC is SE; WPGH Fox is SW.
Just use the green signal lines on the satellite photo. They are oriented to true north, which is at the top of the photo.
Something is affecting your compass, like metal or another magnet. It should be more steady than that. Keep in mind that the compass points to magnetic north. There is a difference of 9 or 10 degrees between true north and magnetic north at your location.
The green signal lines know, use them as a reference with a landmark.
14-Sep-2017, 11:06 PM
#38
Can you give us a list of channels that are important to your wife so that we can see what direction they are in?
Here is a satellite image of your location with a 360 degree protractor to show azimuth directions of your signals:
Does that help?
15-Sep-2017, 2:04 AM
#39
My wife wants the 4 major networks.
We have several choices for 3 of them.
ABC is kind of skinny.
Me, I watch the "sub" stations.
I like to watch Comet which is only available on 6-3 and Cozi, Movies and Retro which is only available on 60-1, 60-2 and 60-3.
That's where I always thought North was but neither of 2 compasses point near there with any regularity.
I guess my magnetic personality affects the compasses.
16-Nov-2017, 11:59 PM
#40
Just an update, of sorts.
I, now, have a helper and hope to move the antenna higher.
I have 2 more sections of mast.
The leaves are gone but reception has diminished and I am receiving fewer and fewer stations on my main TV.
There are 3 TVs in the house connected to the antenna and all get different stations.
The main TV is an Element and it is @ 2-3 years old.
Do you think some of the issues are related to the TV?
The other TVs are Dynex.
None are top of the line.
Thank you for any inputs
