Old 8-Sep-2010, 2:11 AM   #1
Woodsman20
Help with Ant Choice
Need help picking out a good ant. looking at a AntennaCraft HD1850 Heavy Duty or a AntennaCraft CCS1843 TV Antenna or some other setup?
Wooded area but it will be up above the tree line to North West but a mountain behind to the South and East.
Thanks
http://www.tvfool.com/?option=com_wr...a362a323e4d9ae
Woodsman20 is offline   Reply With Quote
Old 8-Sep-2010, 1:55 PM   #2
Dave Loudin
You're on the right track, since you have stations on UHF and both VHF bands. You should consider the Winegard HD8200P, as it appears to have similar performance to the AntennaCraft HD1850, but costs a little less. You will need all the gain you can get. Also, you should tip the antenna a couple of degrees up from horizontal
You might consider a pre-amp such as the Channel Master 7777 especially if your cable run is going to be 50 feet or more.
Old 8-Sep-2010, 7:58 PM   #3
Originally Posted by Dave Loudin View Post
You should consider the Winegard HD8200P.
That's a good choice. Yet, there's one other consideration, last week WTVF applied to move from channel 5 to channel 25. Assuming that things work out you may not need a low band antenna. The wait could be 6 months to several years.
Old 9-Sep-2010, 6:54 PM   #4
Tv Reception
The HD8200P is the way to go , try it with out a preamp first.http://www.solidsignal.com , http://www.starkelectronic.com . point the antenna at the north west group of stations
Old 20-Sep-2010, 1:55 AM   #5
Woodsman20
Where can I find a HD8200p at a good price. I assume you guys are meaning a 8200p and not a 8200u. I found it at summitsource but they have been sold out. I have found them a couple of other places but they are $150+. Neither stark or solid has them?
Old 20-Sep-2010, 12:05 PM   #6
Tv Reception
The HD8200U is a updated HD8200P , the new number is HD8200U. Try these http://www.warrenelectronics.com/antennas/HD8200U.htm - $117.50 . . http://www.winegarddirect.com - referb - $156.94 . . http://www.amazon.com - $131.78
Old 20-Sep-2010, 12:27 PM   #7
Tv Reception
The Antennacraft HD1850 is also a good choice. The Winegard and Antennacraft antennas are Big Antennas that need a very strong mounting.
Old 20-Sep-2010, 4:51 PM   #8
Dave Loudin
Going back to Tower Guy's observation: If you want to gamble on WTVF's move to UHF, then you could go for a Winegard HD7698P or an AntennaCraft HBU-55.
