Old 10-Feb-2012, 7:11 PM   #1
goosemasterkl
antenna help
I'm needing some help on what type of antenna's I need to use at the 2 locations that I'm wanting to put up antenna's at. I already have a HD Stacker antenna and pre-amp. Will it work for one of the locations I'm listing below? Thanks
1)http://www.tvfool.com/?option=com_wr...0b86dddee7cd77
2)http://www.tvfool.com/?option=com_wr...0b8614418e1efb
goosemasterkl is offline   Reply With Quote
Old 10-Feb-2012, 7:26 PM   #2
Are any of these the same as these?? http://forum.tvfool.com/showthread.php?t=7049
Old 10-Feb-2012, 7:38 PM   #3
goosemasterkl
Electron; 1 of them is but with a more accurate lattitude and longitude reading. Thanks
Old 10-Feb-2012, 7:50 PM   #4
The stacker and preamp will most likley work for the first one at , 37.29 , -87.75 .
Old 10-Feb-2012, 8:00 PM   #5
goosemasterkl
Electron; what would you reccommend for the second one? Thanks
Old 10-Feb-2012, 8:41 PM   #6
For the second one , KEVV-DT 45 CBS is very weak , make two more radar reports 40 feet and 60 feet.
Old 10-Feb-2012, 9:01 PM   #7
goosemasterkl
40 ft.-http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d0b86c6fff18124
60 ft.-http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d0b86c249105116
Old 11-Feb-2012, 1:37 AM   #8
40 feet , http://www.tvfool.com/?option=com_wr...0b86c6fff18124 , 60 feet , http://www.tvfool.com/?option=com_wr...0b86c249105116
Old 11-Feb-2012, 2:10 AM   #9
goosemasterkl
Electron; after running them other 2 heights; what do you recommend for an antenna and pre-amp? Thanks for your responses!!!!!
Old 11-Feb-2012, 7:45 AM   #10
For the reception of , NBC , Retro Tv Network , PBS , MyNetwork , The Cool Tv , ABC , Install a Winegard HD7698P antenna with a Antennas Direct CPA-19 preamp aimed at about 310 degree magnetic compass. The antenna will be installed no less then 30 feet high , 40 feet would be better. Here are some Strong and Sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/Tripods%200703/4712.html , http://www.ronard.com/34424560.html. http://www.ronard.com . Here are places to buy antennas and etc. , http://www.winegarddirect.com , http://www.amazon.com , http://www.solidsignal.com. Buy the antenna mounts direct from Ronard or at SolidSignal. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html.
Old 11-Feb-2012, 7:47 AM   #11
How many tv's are/will be connected?? at the second location??
Old 11-Feb-2012, 11:04 AM   #12
goosemasterkl
Electron; they're will be 1 TV at both locations. Would my HD Stacker antenna and pre-amp work at either location? Thanks
Old 11-Feb-2012, 3:13 PM   #13
The stacker will work at the first location. The tv stations/channels are much weaker at the second location.
Old 11-Feb-2012, 3:59 PM   #14
goosemasterkl
Electron; Thanks for all of your support.
