Old 8-Feb-2012, 3:15 PM   #1
goosemasterkl
antenna suggestions
I'm wanting to put up an antenna in a very remote area on a piece of property I own in the country. It is a hilly and somewhat wooded area. I ran the TV Fool signal locater and here are the results. I'd really appreciate any suggestions on what type system I need to put up. Thanks
http://www.tvfool.com/?option=com_wr...0b8689f8d87ece
goosemasterkl is offline   Reply With Quote
Old 8-Feb-2012, 3:35 PM   #2
Make two more tvfool radar reports , the antenna heights at 40 feet and 60 feet. Higher antenna heights can more signal strength.
Old 8-Feb-2012, 4:48 PM   #3
goosemasterkl
antenna suggestions
Here are the readings for 40 and 60 ft.
http://www.tvfool.com/?option=com_wr...0b86ce9a9a81d9
http://www.tvfool.com/?option=com_wr...0b86088dfdf7a3
Old 8-Feb-2012, 5:28 PM   #4
Install a Winegard HD7698P antenna with a Winegard HDP-269 preamp aimed at about 30 degree magnetic compass. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. Mount the antenna and preamp at about 40 feet high , so as to get reliable reception of , WKMA-TV 42 PBS , WEHT 7 ABC , WFIE-DT 46 NBC and This Tv , WEVV-DT 45 CBS and FOX and MyNetwork , WNIN-DT 9 PBS. . Here are some Strong and Sturdy antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/Tripods%200703/4712.html , http://www.ronard.com/34424560.html
Old 8-Feb-2012, 6:53 PM   #5
goosemasterkl
Electron; Thanks so very much for your fast and needed response!!!!!!!!!!
