Old 4-Jan-2012, 9:34 PM   #1
skim8
Help Deciding on Antenna
I live in the Toronto area, and am looking for a good indoor antenna.
TV signal analysis results
Right now, I'm trying out the Terk FDTV1A with a Zinwell ZAT-970A. I get about 14 channels. If I'm reading the TV Fool report right, I should be able to get 21 using a set top antenna.
I thought by using this Terk antenna, I could mount it on the wall as high up as it will go and maybe get better reception.
Should I bother trying the Terk HDTVa? Or should I scrap it all, and just get rabbit ears?
Also, do you guys think I be using an antenna with amplifier?
Any help and advice is greatly appreciated.
skim8 is offline   Reply With Quote
Old 5-Jan-2012, 2:33 AM   #2
http://forum.tvfool.com/showthread.php?t=2828
I would not recommend use of any amplifier or amplified antenna.
The non-amplified Terk HDTVi would be worth your consideration.
An outdoor antenna will outperform an indoor antenna in almost every case. If reception of both local and US signals is a goal, a modest size outdoor antenna and rotator could be used. Let us know if you're interested.
Old 5-Jan-2012, 3:21 AM   #3
That said , The Canada and USA tv stations Will Be received with a Winegard HD7696P antenna aimed at 188 degree magnetic compass. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. . No rotor needed. . For one tv connection , on coax to the tv . For two tv connections use a simple common 2 way splitter. For 3 or 4 tv connections use a Channel Master CM3414 distribution amplifier. Here are some roof top antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html. Here are places to buy antennas and etc. , http://www.winegarddirect.com , http://www.channelmasterstore.com , http://www.solidsignal.com , http://www.amazon.com
Last edited by mtownsend; 5-Jan-2012 at 4:57 AM. Reason: Edited to remove off-topic comments
antenna choice, toronto
