Old 29-Nov-2011, 6:48 PM   #1
Indoor Antennas - Non-amplified
This is a thread dedicated to listing and reviewing Indoor, non-amplified antennas... "Rabbit Ears"
If you need help deciding whether an indoor antenna will work for you or not, please read through the Guidelines when asking for help Then, as directed, post your request in the Help With Reception forum.
My reference to specific retailers pricing is not an endorsement of that retailer. Vendors such as solidsignal.com, summitsource.com, amazon.com, 3starinc.com, frys.com, newegg.com, bestbuy.com... and on and on... are all worth considering when shopping.
As a general rule I am inclined to recommend non-amplified indoor antennas. I won't go so far as to say, "Never consider an amplified antenna." However, my opinion is that if signal conditions are strong enough to make an indoor antenna worth your consideration, use of any sort of amplifier is generally not needed. Amplifiers can be overloaded by strong signals, at which point the quality of the received signal will be reduced to the point were reliable reception is affected. Amplified antennas also cost more... but rarely give you any additional benefit that can be observed on the TV screen.
Most rabbit-ear style antennas have adjustable length rods that are intended to receive VHF frequencies. Here is a list of the estimated length for each VHF channel.
For 1/4" diameter dipole rods
Estimated length of each rod
Calculated using 4NEC2
Channel - Rod Length
2 ------- 49 3/8"
3 ------- 44 5/8"
4 ------- 40 3/4"
5 ------- 35 1/2"
6 ------- 33"
7 ------- 15 5/8"
8 ------- 15 3/8"
9 ------- 14 5/8"
10 ------ 14 1/4"
11 ------ 13 3/4"
12 ------ 13 3/8"
13 ------ 13"
Post #2 in http://forum.tvfool.com/showthread.php?t=11 provides additional information about the technical performance of the typical set top antenna.
Old 29-Nov-2011, 6:55 PM   #2
Zenith VN1ANTP1
As of 11/29/2011, the Zenith VN1ANTP1 is priced at under $5 at Amazon.
A basic indoor antenna. Typical of most basic 'rabbit ears'.
Capable of reception of VHF and UHF signals (CH-2 through 69) when signals are strong and not subject to multipath, adjacent or co-channel interference.
Old 29-Nov-2011, 7:01 PM   #3
Rca ant-111
As of 11/29/2011 the RCA ANT-111 is priced at less than $10 at Amazon.
A basic indoor antenna. Typical of most basic 'rabbit ears' in performance. A bit more modern appearance than the classic 1950's style rabbit ears.
Old 29-Nov-2011, 7:17 PM   #4
Rca ant-121
As of 11/29/2011, the RCA ANT-121 is priced at under $13 at Amazon.
Essentially the same type antenna as the ANT-111 and other similar 'rabbit ears', with the addition of a front panel adjustment knob which presumably switches element sections in or out of the circuit. While not necessarily a gimmick, the addition of this 'variable' may needlessly complicate the operation and adjustment of an antenna that could otherwise be set and then left alone.
Old 29-Nov-2011, 7:31 PM   #5
Terk HDTVi
As of 11/29/2011, the Terk HDTVi retails for about $30 at Amazon.
Be careful to avoid confusing this antenna with the HDTVa which includes a built in amplifier. If signal conditions are strong enough to use an indoor antenna, an amplifier is generally not needed and in many cases, a source of trouble due to signal overload.
Capable of reception of VHF and UHF signals (CH-2 through 69).
The performance on Channel 2 through 13 is about the same as most other 'rabbit ear' style antennas, minimal gain and minimal directivity. Expect virtually the same VHF reception in both directions perpendicular to the VHF rods.
This antenna does offer some gain on UHF channels 14 through 69. The antenna will be more sensitive to UHF stations in the direction the antenna is pointed. (The longest wing like elements are the back, the shortest wing like elements are the front of the antenna.) The modest gain also results in the antenna having the ability to reject some multipath interference.
Post #3 in http://forum.tvfool.com/showthread.php?t=11 provides additional information about the technical performance of a similar design.
Old 29-Nov-2011, 8:29 PM   #6
Mohu Leaf
As of 11/29/2011, the manufacture's web site offers the Mohu Leaf for $39.99
The vendor's web site and ad copy only provide physical dimensions of the antenna, no bandwidth or gain data was found. The folks at digitalhome.ca have a dedicated thread, http://www.digitalhome.ca/forum/showthread.php?t=138226
This antenna is reported to have nominal performance when used for UHF reception. It's VHF performance is reported to be less than that of a typical VHF dipole.
At $40, some may consider the esthetics of the product worth the price... others may not place that much value on looks.
Old 20-Jan-2012, 3:25 AM   #7
Channel Master CM-4010
As of 1/19/2012, the CM-4010 is priced at under $23.99 at the manufacturer's online store.
Old 7-Apr-2012, 5:53 AM   #8
Antennas Direct SR8 Directional UHF Only
As of 4/6/2012, the Antennas Direct SR8 Indoor Antenna is priced at $18.99 at the manufacture's online store.
This is a directional antenna with more than 4 dBd forward gain. (6.5 dBi per the manufacturer.)
This would be a good choice in a market served only by real UHF broadcasts and where the stations are grouped within 40° of each other.
This type antenna can also help overcome more multipath interference than the basic UHF loop element on most indoor antenna designs.
Best for reception of real channels 14 and higher, though strong signals in the VHF bands may be received.
