Old 22-Feb-2014, 9:32 PM   #1
CAMFRAN
Flat wave antenna will not pick up PBS ch 11
The Wineguard Flatwave amped antenna picks up 31 stations but not the one I want, Chanel 11 PBS in New Orleans. It should be possible according to your site. It is indoors and I have tried facing the antenna in the direction that your site listed for my area and still no PBS. The antenna is about 15' off the ground. Our house is wooden there are high power lines outside on the other side of the street. All other channels look great. I have scanned several times over a period of weeks. I saw a review where it was noted they could not get PBS either, this was not anywhere near me!
Any advise would be appreciated.
CAMFRAN is offline   Reply With Quote
Old 22-Feb-2014, 10:01 PM   #2
Please post a link to your TV Fool reception report.
I presume you are referring to WYES, real CH-11. The small flat antennas are best suited to reception of real channels 14 and higher.
The New Orleans market is a candidate for antennas that have both UHF and High-VHF capability. Consider the Terk HDTVi.
http://forum.tvfool.com/showthread.php?t=2828
Old 23-Feb-2014, 12:24 AM   #3
CAMFRAN
Thank you
That was a fast response and thank you so much I am not sure what I would have done without you guys! I will go that route.
Old 23-Feb-2014, 4:08 PM   #4
Please make and post a tvfool report using the Exact address to make the report and make the antenna height in the report 25 feet above ground.
Go to the tvfool home page and click on >>Start MAPS<<.
Click on the Make Radar Map Button , and post the tvfool report.
If the Exact address does not work to make the tvfool report then enter zip code only and move pointer to the Exact location , make the antenna height 25 feet above ground.
Click on Make Radar Map Button , and post the tvfool report.
25 feet antenna height above ground is a Reference Antenna Height that provides a good idea of what is receivable.
