Old 16-Dec-2011, 4:28 AM   #1
harr2plus
Antenna recommendations
First, thanks in advance for any advice / help.
Here is the analysis link: http://www.tvfool.com/?option=com_wr...4033e218381af7
I'm looking for an antenna (and possibly a preamp) for my mother's house. I've seen quite a bit about the Clear Stream 2 and 4. I would like to give her the opportunity to get as many channels (within reason) as possible. The CS4 with pre-amp combo is about $160. Is there an equivalent, more cost effective alternative? What other brand(s) should I think about or avoid?
If I'm missing any info, please let me know and I'll furnish it.
harr2plus is offline   Reply With Quote
Old 16-Dec-2011, 4:36 AM   #2
Tv Reception with Tv antennas
Old 16-Dec-2011, 7:28 AM   #3
The stations south and slightly east, listed in the green section of your report are going to be easy to receive reliably with the C2 or C4.
These 4-bay UHF panel antennas are competitive, and sold by reputable companies.
U4000, DB-4, DB-4e, CS4, CM-4221 or HD4400.
http://www.antennacraft.net/Antennas/AntennasUHF.html
http://www.antennasdirect.com/store/...-Antennas.html
http://www.channelmaster.com/Channel...ntenna_s/3.htm
http://www.winegarddirect.com/cview....nly%20Antennas
Any of these antennas should have no trouble feeding 1 to 4 sets with no amplifier needed, there is plenty of signal power at your location.
If your mother is interested in religious programing, a high-VHF antenna pointed at 79° compass will provide reliable reception of WINM. An Antennacraft Y5713 would be my suggestion. To combine the UHF antenna and h-VHF signals into one down-lead, use a UVSJ.
Old 16-Dec-2011, 11:42 AM   #4
harr2plus
GroundUrMast: Thanks for the recommendations. I'll check them out.
She will have up to 4 TVs connected. However, only two will likely be on at any given time. Also, as it was late last night when I posted, I neglected to mention that she also has an antenna rotor already in place.
