Old 12-Aug-2011, 5:56 PM   #1
CheapChannels
Outdoor Antenna Suggestions for Toronto
Could anyone suggest a good outdoor antenna for East York, Toronto. I'm considering a rotor and it will be roof mounted on a two story home.
Alternately, anyone care to share their opinion on an attic set up?
CheapChannels is offline   Reply With Quote
Old 12-Aug-2011, 6:28 PM   #2
As the other question askers do , Do This --> http://forum.tvfool.com/showthread.php?t=4. Use the exact address , height the antenna will be at.
Old 12-Aug-2011, 6:33 PM   #3
CheapChannels
http://www.tvfool.com/?option=com_wr...3e47626b6d72de
Old 12-Aug-2011, 9:03 PM   #4
You're very close to your local transmitters, so a modest antenna, like the RCA ANT-751, will be just fine. If you want to chase the Buffalo stations, you will need a much larger UHF antenna, like the Antennas Direct DB-8, Winegard HD8800, or Antennacraft U8000, that can be aimed right at them. Run separate feeds from the antennas to an A/B switch at the TV.
Old 13-Aug-2011, 10:43 PM   #5
CheapChannels
Rotation?
This suggestion doesn't seem to work on a rotor. Should I be worried?
Anyone have luck with an attic set up?
Old 14-Aug-2011, 10:28 PM   #6
Why would you need to rotate them? The RCA is for your local channels (240 degrees) and the other UHF antenna is for Buffalo (165 degrees). Aim them in the proper directions and leave them alone. If you don't want the Buffalo stations, just buy the RCA antenna. You will not need to turn it.
You could just buy one of the UHF antennas I recommended and rotate it between the two positions. Your choice.
Before you spend any money, look over the indoor and outdoor reception results for your area at digitalhome.ca.
Old 14-Aug-2011, 10:54 PM   #7
How many Tv's are/will be connected?? . You will not be chasing the American stations , you will be receiving the American stations. For my recommendation I need to know if more then one Tv will be connected. How many Tv's will be connected??
Old 15-Aug-2011, 2:40 PM   #8
CheapChannels
Only one TV. Yes I'd like to go after the American channels.
Thanks for all the help with this guys.
Old 16-Aug-2011, 7:43 PM   #9
I got pulled in on this one because I was not looking real close. These Question and Answers Belong in the --> Help With Reception <-- part of tvfool.
Old 16-Aug-2011, 10:13 PM   #10
Thread moved to Help With Reception area.
Old 17-Aug-2011, 11:54 PM   #11
Ok here goes. . The Canada Tv stations/channels are Very Strong I suggest a Channel Master CM2016 antenna aimed at about 245 degree magnetic compass , No amplifier will be used because the Canada stations are very strong. . For the American stations I recommend a Antennas Direct 91XG with a Winegard HDP-269 preamp aimed at about 170 degree magnetic compass. A coax will go from each antenna to the location of the Tv. And a remote control A/B switch will switch from one antenna and the other antenna so you can select the 2 antennas with out getting out of your chair. http://www.saveandreplay.com has the antennas the preamp and the remote control A/B switch. And also has coax cable and etc. .
Old 18-Aug-2011, 12:08 AM   #12
Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html . also read and understand about , REAL Digital Broadcast Tv Channels , Virtual Digital Broadcast Tv Channels , Analog Broadcast Tv Channels , http://forum.tvfool.com/showthread.php?t=695 Also here is more information about Canada digital Tv. http://www.user.dccnet.com/jonleblan...da_TV_Stations , http://www.tvtechnology.com/article/117022 , http://www.tvtechnology.com/article/105462 , http://www.digitalhome.ca/forum , http://www.saveandreplay.com , http://www.trentondistributors.com , http://www.friends.ca , http://www.crtc.gc.ca/eng/home-accueil.htm , http://www.canadapost.ca/shopper
Old 18-Aug-2011, 12:19 AM   #13
Here are some but not all free tv guides for Canada and American stations , http://www.canada.com/entertainment/...ion/index.html , http://www.tvzap.com , http://television.aol.com , http://www.tvyahoo.com , http://www.zap2it.com , http://www.titantv.com ,
antenna choice, toronto
