Old 1-Aug-2011, 1:16 AM   #1
Jim5506
KBIM-DT 10(10.1) no coverage map
Using the Map facility inputting the 88201 zipcode for Roswell, NM, KBIM-DT 10(10.1) has no coverage map associated with the station, any reason why?
I live in Lubbock TX and was trying to see if feasable how tall a tower I'd need to pull in KBIM-DT and KOBR-DT from Roswell, but there is no coverage map showing for KBIM-DT.
Jim5506 is offline   Reply With Quote
Old 1-Aug-2011, 9:27 PM   #2
The reason for the missing coverage overlay is because the FCC recorded a change to their callsign. It used to be KBIM-TV, and it is now KBIM-DT. This makes the transmitter look like a "different" transmitter than what we have in the overlay database.
Coverage overlays take a long time to re-process, and they can lag behind the "current" database by several weeks. Since the map tool is not finding a match for KBIM-DT in the overlay database, it is saying that it cannot display a corresponding coverage map.
As an immediate fix for this, we will make the KBIM-DT coverage overlay match the KBIM-TV overlay (since transmitter specs have not changed, the overlays ought to be identical) without having to wait for the next round of re-processing to finish.
I hope this helps.
Old 4-Aug-2011, 6:13 AM   #3
canant
Any idea when the "pending" coverage overlays will be updated? Industry Canada updated its database to include CBUFT-DT on May 18, 2011 and TV Signal Locator started listing that transmitter within the same week. As of yet there is no overlay map.
canant is offline   Reply With Quote
