Old 21-Jul-2011, 1:10 PM   #1
ramori
Angry Newbie help! Why do i get Zero digital signals with 3 different antennas?
I don't consider myself an idiot when it comes to AV tech, but I'm frustrated beyond all h$ll . I want to cut the cord on my sat. subscription, but I can't seem to get any antennas to work in my attic or even rooftop. Here's my signal survey: http://www.tvfool.com/?option=com_wr...03f30f39257249
Here's what I've done so far, to no avail. What am I doing wrong?
1) Purchased 3 different antennas (from Meijer and Radio Shack). Ranges on the box very from 40-70 mile range. The stations from Detroit are less than 50 miles from my house. Also purchased 2 different signal amplifiers.
2) Climbed into my attic (boy it's hot in there!). Connected the coax from the bedroom directly to the antenna. Did a channel scan, but only detected 3 analog stations. Added a signal amplifier, but no more channels detected.
3) Bought two more antennas and tried them all. Can only detect the same 3 analog stations! Even climbed up on my roof, connected to the coax from by sat dish, and still had no digital channels detected. I have many tall trees between me and Detroit (Northeast), but they are about as tall as my house. So I figured if I stood on my roof the antenna(s) would work. But nope, nothing.
My TV is digital, but is about 8-10 years old.
Why do I get absolutely no signals?
ramori is offline   Reply With Quote
Old 21-Jul-2011, 2:32 PM   #2
Very few TVs of that vintage have digital tuners in them.
Old 21-Jul-2011, 2:47 PM   #3
ramori
I just realized that as well. I should not assume that Digital Ready means it has a digital tuner! I will buy a converter box tonight and try it again.
The confusing thing is that I can pick up 3 canadian stations, so I figured that since I was getting something, my TV was OK. But I only discovered today that those 3 stations are analog, not digital. I think the converter should do the job.
Old 21-Jul-2011, 3:39 PM   #4
"Digital Ready" means that it's ready for your external digital signal source such as a cable or satellite set-top box, fed in by DVI, HDMI, or component cables. It also means it doesn't have a digital tuner.
The inexpensive digital converter boxes (under $60) are standard def only.
Old 21-Jul-2011, 5:55 PM   #5
Here are reliable converter boxes , http://forum.tvfool.com/showthread.php?t=380 , if it's a simple plane jane converter box it will have 480i output. Here are the digital broadcast Tv resolutions , 480i , 480P , 720P , 1080i , 1080P . Also read and understand about , REAL Digital Broadcast Tv Channels , Virtual Digital Broadcast Tv Channels , Analog Broadcast Tv Channels , http://forum.tvfool.com/showthread.php?t=695
Old 21-Jul-2011, 6:09 PM   #6
The default antenna height is 10 feet. Run the tvfool report with the antenna height as high as the roof top.
Old 21-Jul-2011, 7:14 PM   #7
The boxes that I have listed I have done way more research then a sane person would the boxes are reliable dependable. The Access HD DTA 1080 that gcd0865 has listed has proven to be a defective box , I have replaced the DTA 1080 in customers homes it gets hot and stops working. I did a lot of research to find the boxes I have listed so that people will have dependable and reliable boxes that serve a wide varity of purpose.
Old 21-Jul-2011, 11:55 PM   #8
How many Tv's will be connected??
Old 22-Jul-2011, 9:03 PM   #10
Here are some but not all tv guides , http://www.zap2it.com , http://tv.yahoo.com , http://tv.entyertainment.excite.com , http://www.tvzap.com , http://www.canada.com/entertainment/...ion/index.html , http://television.aol.com , http://www.titantv.com
Old 23-Jul-2011, 5:27 AM   #11
If you identify the antennas and amplifiers that you have I can help with the selection of antenna/s and amplifier/s to use. And aiming of antenna/s. . . How many Tv's will be connected??
michigan
