Old 29-Apr-2024, 12:48 AM   #1
davodavo
AntennaCraft HBU55 gain specifications?
I know, I know...it's been forever since they went out of business.
But I'm hoping somebody here has a pointer to gain specs for the HBU55...I'm particularly interested in how bad its low-VHF specs were.
It seems that the high-VHF was around 11 dB over reference dipole...
I'm using one of these, and it does pick up VHF 5...but it misses potential channels at 2, 4, and 6. Trying to understand what improvement is possible with a replacement antenna...(I'm already using a quality preamp, so there's no potential there.)
Thanks for any info / pointers you can provide at this late date.
David
davodavo is offline   Reply With Quote
Old 2-May-2024, 8:42 PM   #2
David
Hello, David.
The HBU55 doesn't have specs for 2-6 (VHF-Low) because it wasn't designed to receive that band.
For a replacement antenna, consider the Televes Televes DAT Series BOSS Mix LR Low-VHF/High-VHF/UHF Antenna
https://www.amazon.com/Televes-Anten...dp/B0B94KX7GM/
or the
Solid Signal Xtreme Signal Long Range HD VHF UHF FM Outdoor TV Antenna (HD8200XL)
https://www.solidsignal.com/xtreme-s...tenna-hd8200xl
https://blog.solidsignal.com/tutoria...pulls-vhf-low/
antenna specifications, antennacraft, gain
