Old 21-Mar-2018, 11:05 PM   #1
Lennycorn
Newbie here. Is OTA a route for me
Hello all
I'm thinking of cutting the cord and want to know if a path for me.
I'm looking to get the the three big network and even more the better.
I've been reading the forum and find the information a tad confusing.
So here is my report.
http://www.tvfool.com/?option=com_wr...90382128a8abcc
I'm think of install the antenna 25 feet up on my gable end of the house, running a coaxial line from antenna to the current outside cable splitter.
Which from there will connect all 4 tvs.
I'm thinking a muti- directional antenna with and amp but wanted you thoughts on if it's worth it for my location and what is a good antenna for the job?
Thank you for your thoughts
Dave
Old 22-Mar-2018, 1:04 AM   #2
Hello, Dave; welcome to the forum.
I see you are now able to post. Your report is only resolved to block level because you left out the W in your address. With the W added, it looks like this:
http://www.tvfool.com/?option=com_wr...9038e57cfb1d0b
NBC is no longer on WMGM, so you need to find a different channel for that.
https://en.wikipedia.org/wiki/WMGM-TV
WWSI is your strongest NBC, but it is to the north; most of your networks are SW.
You might be able to get everything with a UHF antenna aimed SW:
WMDT ABC, 232° true, 244° magnetic
It will be moving to channel 29 because of UHF Channel Repack:
https://www.rabbitears.info/market.p...&callsign=wmdt
WRDE NBC/MyN, 217° true, 229° magnetic
https://www.rabbitears.info/market.p...&callsign=wrde
WBOC CBS/Fox, 229° true, 241° magnetic
It will be moving to channel 32:
https://www.rabbitears.info/market.p...&callsign=wboc
I suggest an Antennas Direct 91XG or Solid Signal HDB91X antenna and an Antennas Direct Juice preamp. No guarantee, because your signals are weak.
