Old 17-Oct-2016, 4:54 PM   #1
dalexop
Noob
Help in Lindsay Ontario
Hi folks,
I am in Lindsay Ontario and I've installed a WG HD 7698P deep fringe antenna.
It's on a 50 FT tower.
I also have a Channel Master amp hooked up.
It's either a 7777 or 7778 ( Need to validate this & respond back )
The Signal report is here:
http://www.tvfool.com/?option=com_wr...e2cb62f98709e9
I find all stations drift in and out of reception throughout the day.
I may put another amp just prior to the TV since the line runs down the tower, and through the house about 25 to 30 feet.
I do not have a Rotor, pointing the antenna towards the CN tower.
Anyone have further ideas on what I can to to improve my chances at reception ?
dalexop is offline   Reply With Quote
Old 22-Oct-2016, 3:19 AM   #2
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
Another amplifier isn't going to help you, and in the face of the strong CBC station nearby, could actually hurt you. Toronto appears to have a massive escarpment between you and it, and the signals present from the Toronto stations are unlikely to be reliable under the best of circumstances. I would suggest that you consider installing a rotator, and look for programming from The Rochester, NY stations for US channels, and it appears that you already have CBC, Global, CTV2 and Radio-Canada nearby. At least you'll see Hockey Night in Canada
