Go Back   TV Fool > Over The Air Services > Special Topics > Digital TV and Mobile DTV
Old 20-Feb-2015, 7:50 AM   #1
dalis
Wink Help with TV to work with OTA
Really liking the idea and having fun playing with OTA. Not sure if I'm posting in the right forum but I have a problem with the television.
Made a simple antenna with two wires and just wanted to see what channels I could get. Indoor and scanning two tvs I was able to pick up 13 channels, if I held the antenna near the window.
Our shower has a waterproof TV from China. It has PAL and NTSC and my settings are correct for north america. I can scan with cable company and picks up channels but with my homemade antenna I get nothing. The tv when it scans it scans mhz from approx 100-900mhz and then stores the channels in the presets.
My question is what kind of tv do I have? Will it ever work with OTA? Is it just my homemade antenna not letting me pickup channels. Do I need a combo vhf/uhf antenna? Thanks in advance
dalis is offline   Reply With Quote
Old 20-Feb-2015, 12:30 PM   #2
timgr
If it scans cable channels, then it should not scan OTA channels, and vice-versa. There should be a menu setting somewhere that switches from ATSC (digital OTA) encoding to QAM (cable) encoding. NTSC won't work anymore - there is almost nothing in the air that is NTSC encoded (and what little is left is required to be gone by 2015). Set to cable mode, you should get nothing from an antenna.
You'd probably be better off posting in the "Help with Reception" forum here. That's more on topic for you and is much more active than this forum.
Old 21-Feb-2015, 4:16 AM   #3
One without a digital tuner which makes it useless for antenna TV without a converter of some kind.
Can't say I've ever seen a TV for IN the shower....
Old 21-Feb-2015, 4:30 AM   #4
dalis
I went searching everywhere in the menu, could not find any place to switch it to antenna
Adtech: We've had this shower for about 8 years, attached pic of it. Same as this one
Looks like I'm sol because our hot tub has the same tv but 19" from a US supplier.
