Old 21-Jul-2014, 3:01 AM   #1
Redriver64
Question Can't get major channel
Can not receive KSLA ( CBS Shreveport , LA in Texarkana.
Receive many other stations from Shreveport, even weaker ones.
All are on almost same azimuth and all are aprox. 53 miles.
Bought a "150 mile" antenna. So why can't I get KSLA?
http://www.tvfool.com/?option=com_wr...e1c61a7be57b99
Redriver64 is offline   Reply With Quote
Old 21-Jul-2014, 7:55 AM   #2
I wish more folks could be warned away from '150 mile' antennas before they waste their hard earned money. If the antenna is what I suspect it is, a cheap bit of plastic, aluminum and a dubious built-in amplifier, please accept my condolences. I hope you didn't pay much.
Before you spend more money, try moving the antenna to a new location and also try changing the height, both up and down from the present position.
If you exhaust all reasonable options, and find no satisfactory mounting location, consider upgrading to an Antennas Direct DB4E or DB8E.
Old 21-Jul-2014, 4:29 PM   #3
Stereocraig
If you are unable to achieve positive results, consider returning the antenna for a refund.
It will be only a matter of time before the motor/ gears deteriorate.
Old 21-Jul-2014, 5:36 PM   #4
StephanieS
It is shocking in the modern era such inaccurate marketing is allowed to persist. Are we returning to the 1910 JC Penny catalog with all sorts of untested potions and so-called ailment cures?
Sorry... (rant off)
Old 21-Jul-2014, 5:46 PM   #5
Stereocraig
Sorry... (rant off)
Maybe if more people would rant, some things would change.
That's the nice thing about standards, though.
There are so many to choose from =D
Old 21-Jul-2014, 6:55 PM   #6
Redriver64
None of that explains why I get all the others and not that one when they are all on same line and distance
Old 21-Jul-2014, 7:38 PM   #7
In order to answer your question logically the manufacturer of the antenna would need to publish antenna gain and patterns plus preamp gain, noise figure and overload characteristics. That is all missing, so no one can tell you why the antenna fails on KSLA.
Old 21-Jul-2014, 8:19 PM   #8
I would simply assume it's in a dead spot for that particular station. Moving the antenna is the necessary remedy. It might take a mere 6" or 6' or 6 yards in any direction.
Old 21-Jul-2014, 9:57 PM   #9
Stereocraig
I have on occasion, received stations from as far as 154- 156 miles away consistently, while not being able to lock on one that is 39 miles away and stronger.
Just the nature of the beast, I guess.
At the end of the day, there is only one Absolut.
The one w/ the olive(s) in it
Old 21-Jul-2014, 10:32 PM   #10
Jake V
I'm curious.
Your TVFool map is only resolved to the block level. It's probably good, but it would be useful to prepare a more accurate version. Go to Online TV Maps, enter your address and click "Map This", then switch to "Satellite" at top right, zoom in and move the red pointer so that it is over your house, set the antenna height and let it update, then click on "Make Radar Plot" and post that link here.
In the end you'll probably want to upgrade to a better antenna.
Old 23-Jul-2014, 7:33 PM   #11
Above the Peak of the Roof in such a manner that the roof and building do not , obstruct , impede , block , reception in the directions of , South , South West.
Install a , Antennas Direct , DB8e antenna aimed at about 190 degree magnetic compass direction.
http://www.amazon.com.
As a Test to Prove Reception connect a New Continues Length of Coax to the DB8e antenna , and run the New Continues Length of Coax through a Open Door or Window Direct to 1 Tv , No couplers , No splitters , No amplifiers , No etc. .
Absorbing and Blocking Broadcast Tv Reception.
Multi-Path Reflecting = Tv Signals Bouncing All Around.
The Best Practice for Reliable Reception is to install the DB8e antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building in the directions of reception.
A antenna system amplifier will most likely not be required for 1 or 2 Tv's connected.
Here are some and not all above the roof antenna mounts.
Use the , ronard (911) , 5 foot tripod antenna mount.
Use the , ronard (4560) , eave antenna mount.
http://www.ronard.com/ychim.html.,
Measure around the chimney and use a , ronard (2212) or ronard (2218) or ronard (2224) .
