Old 7-Apr-2014, 12:46 AM   #1
brg88tx
has anyone ever combined a cs5 and cs2?
and I don't mean 2 separate antennas on a mast, I mean take the tapered loop element "8" off the cs2 and fasten it on the reflector screen of a cs5. to me this would be the ideal compact solution to get over 10 dbi uhf gain and over 7 dbi vhf gain. is it even possible?
brg88tx is offline   Reply With Quote
Old 7-Apr-2014, 3:58 AM   #2
I'm guessing you could be the first.
If you take care, the two antennas could be reassembled if the experiment fails. I'd use the UHF/VHF combiner that ships with the CS5 to combine the two bands.
Old 7-Apr-2014, 10:16 AM   #3
This was an idea explored by our engineer back when the C5 was in development.
The idea was rejected because the negative interactions between the elements was too great. I remember seeing the simulations and they were not pretty.
Now, that doesn't mean you can't get it to work at some level, it meant that it wasn't a viable option for a commercialized product.
Old 7-Apr-2014, 3:39 PM   #4
Putting antennas close together one inside the other like that will produce negative results.
Antenna cross talk detunes both antenna.
You like the look of the vertical flat panel antennas.
I recommend install 2 separate antennas separated by 3 feet or more.
Install a Antennas Direct , Clear Stream 4 .
And the , C5 .
The C5 comes with a combiner to combine the , CS4 and C5 , antennas.
It is also Ok to install the CM4228HD , vertical flat panel antenna.
The best way to do reception is to have Reliable Reception First with a antenna.
And then Experiment with other antennas and modifications of antennas.
You can run a separate coax to Tv/Reception Equipment in your , Experiment Room.
I think you will like to do , Tv DX and Radio DX , the projects will be interesting for a Long Time.
http://www.summitsource.com.
Has the Antenna Craft , G1483 series of flat panel antennas , 4 bay , 8 bay , ANSG 16 bay .
The G1483 antennas are a old antenna design , known as the Gray Hoverman.
The Hoverman is more research for you to do , The design is a basic fractal antenna design.
Last edited by teleview; 8-Apr-2014 at 6:33 AM. Reason: Clarify information and typos.
