Old 1-Mar-2014, 2:55 PM   #1
Jeepwx03
Dillsburg, PA: Help with picking the right setup
I'm attempting to get rid of the evil Comcast Goliath. I would like to have an entire house antenna to attempt this, info on my house and location is below:
http://www.tvfool.com/?option=com_wr...5b94b04b08b46d
I have a ranch home and would like to mount the antenna in the attic.
My current coax is all ran to the outside of the house to one large slitter. I do have 1 connection that is split off one of those feeds.
The stations we would like to get: ABC, NBC, CBS, and Fox
Let me know if I need to provide more information.
Any help would be appreciated, thanks!
Jeepwx03 is offline   Reply With Quote
Old 2-Mar-2014, 9:48 PM   #2
If your attic is a reception friendly environment (many are not), then the five signals listed at the top of your report would be fairly easy to receive with an antenna such as the Antennacraft HBU-22 or HBU-33.
WPMT may require an outdoor antenna. The Antennas direct 42XG would be a good option, but the larger 91XG or DB8E is not overkill.
Combining two antennas that serve the same band (UHF in this case) can be a bit of added complexity, but you have options... http://forum.tvfool.com/showthread.php?t=2882
