Old 13-Jan-2014, 4:24 PM   #1
Quimby
Need some advice for an Antenna
I just cut the cord with my cable company and it feels great! I still get internet through them, but once I get this antenna thing figured out and installed, I am going on a quest to find cheap reliable internet.
So I have done some research and have found I am anywhere from 30 to 50 miles away from the transmitters. We live up on a hill, but we do have trees and homes near us. I was in Best Buy last night and they told me that where we live, there is no indoor antenna that will work. We bought a cheap RCA indoor one just to see if we could get a signal. After messing around, we were able to get 3 channels and that was it. That was only if I held the antenna in the top left corner of the window. As soon as I moved it, the signal was lost.
I am looking for some advice on antennas to look at purchasing and reliable places to buy them from.
Here is the link to the details of my location:
http://www.tvfool.com/?option=com_wr...5b9496d2fae169
Thanks for the help.
Quimby is offline   Reply With Quote
Old 13-Jan-2014, 8:55 PM   #2
If you are willing to consider outdoor mounting, you can have access to the full range of available programing.
I would have no shame using my roof top or chimney as the base for mounting an Antennas Direct DB8e facing south as a starting aim point and an Antennacraft Y10713 pointed at about 190° per a compass. Combine both antennas using an RCA TVPRAMP1R preamplifier.
Old 13-Jan-2014, 10:11 PM   #3
A Simple reception situation.
A 1 Antenna Solution.
Above the Peak of the Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the directions of , South West , South , South East , North West.
HBU44 antenna aimed at about 180 degree magnetic compass direction.
Install a , http://www.channelmasterstore.com , CM7778 preamplifier.
Fo 3 Tv's connected use a , Holland Electronics , HFS-3D , 3 way splitter.
Buy the , HFS-2D and HFS-3D , splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
Digital Broadcast Tv Tuners can develop - Digital Glitches - that are not cleared out with simple channel scans.
The Digital Tv Must Channel Scan for the , ATSC-Digital Broadcast Tv Stations/Channel.
Buy the ronard antenna mounts at , http://www.solidsignal.com , by typing , ronard(x) , in the solidsignal serach box or buy from , http://www.ronard.com.
http://www.amazon.com.
http://www.solidsignal.com.
