Old 12-Sep-2013, 1:10 AM   #1
browndk26
Antenna advise in Louisville, KY
What antenna would be recommended for my location?
Interested in the ABC, CBS, NBC, FOX and PBS stations.
http://www.tvfool.com/?option=com_wr...46ae3bda944bb9
browndk26 is offline   Reply With Quote
Old 12-Sep-2013, 5:03 PM   #2
A Simple reception situation that will receive Many Digital Broadcast Tv stations/channels.
Above the roof in such a manner that the roof and building are not impeding and blocking reception in the directions of , North west , South West , South , South East , East.
Install a ANT751 or Antenna Craft HBU11 , antenna aimed at about 312 degree magnetic compass direction.
Use a Old School magnetic compass to aim antenna.
______
Use no antenna system amplifier.
______
______
For coax that is exposed to weather/water use New coax that has the Compression type connectors on the ends of the coax , not the old crimp type connectors.
To make double sure that weather/water does not get into outside connections wrap http://www.coaxseal.com.
http://www.solidsignal.com.
http://www.amazon.com.
http://www.antennacraft.net.
______
As always , trees and tree leaves , plants and olant leaves , have a Negative effect on , OTA=Over The Air , Broadcast Tv reception , and so buildings and other obstructions in the directions of reception including your own roof and building.
The Best Practice is to install the ANT751 antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or ' Antenna channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Scan for channels.
Last edited by teleview; 13-Sep-2013 at 8:50 PM. Reason: Clarify information and typos.
Old 13-Sep-2013, 1:29 AM   #3
browndk26
Teleview,
Thanks for the recommendation. Any recommendations on how to mount this antenna to a chimney? If you need pictures I can take some tomorrow.
Old 13-Sep-2013, 8:28 AM   #4
Ronard has a well deserved reputation... Consider their stainless steel strap chimney mount options.
http://www.amazon.com/s/ref=nb_sb_no...for+tv+antenna
Old 13-Sep-2013, 8:53 PM   #5
http://www.ronard.com.
Old 26-Sep-2013, 12:50 AM   #6
browndk26
This antenna was recommended by an installer today. Any opinions?
http://www.solidsignal.com/pview.asp...&sku=157983987
