Old 11-Sep-2013, 2:32 AM   #1
Mountainshack
Antenna siting?
I live on a pretty wooded site near the top of a hill. Here is the tvfool report:
http://www.tvfool.com/?option=com_wr...46aeb7cac4295d
One question I have is will getting a more powerful antenna or amplifier help with getting the signal thru or over the trees? Im interested in getting channels in the 116-117 degree area. I tried an indoor mohu leaf ultimate which picked up several channels nearby, but the most critical ones, ABC CBS NBC did not come in clear. Several channel seemed to be clear but would break up and I'm assuming that is because of the trees.
I'm assuming that an amplifier only will improve or help the signal get from the antenna to the tuner and adding a more powerful one won't help the reception.
Is there anything that will help clear up the signal or is the only option to get higher than the trees... that would be about 40-50 feet...
Mountainshack is offline   Reply With Quote
Old 13-Sep-2013, 8:57 AM   #2
You're right, amplifiers are for pushing a signal through the loss of cable and splitters. They don't 'pull' signal out of the air or an antenna.
Given the trees, a Winegard HD7698P or the 'big guns' (an Antennas Direct 91XG and Antennacraft Y10713) are not overkill IMO. If you have more than 50' of coax between the antenna(s) and the TV, add an RCA TVPRAMP1R preamplifier. If mounting outdoors, below tree top level leaves you with unreliable reception, you'll need to consider options that would put the antenna(s) safely above tree top height.
Old 13-Sep-2013, 8:41 PM   #3
For reception of Many of the Raleigh area Digital Broadcast Tv stations/channels.
Install a Winegard HD7698P antenna above the roof in such a manner that the roof and house are not impeding and blocking reception in the directions of , South , South East , East , North East , South West , West , North West.
Aim the HD7698P antenna at about 110 degree magnetic compass direction.
Use a Old School magnetic compass to aim antenna.
____________
Install a Winegard , LNA-200 'Boost' XT antenna system amplifier.
____________
For 2 Tv's connected use a , Holland Electronics HFS-2D , 2 way splitter.
For 3 Tv's connected use a , Holland Electronics HFS-3D , 3 way splitter.
Buy the Holland Electronics HFS splitters at , http://www.solidsignal.com.
____________
Here are some strong and sturdy antenna mounts.
10 foot tripod antenna mount.
Measure chimney and use a , ronard(2212) , ronard(2218) , ronard(2224) , chimney antenna mount.
Buy the ronard antenna mounts at solidsignal or buy from ronard.
___________
http://www.amazon.com.
___________
As always , trees and tree leaves , plants and plant leaves , in the directions of reception , have Negative effect on broadcast Tv reception , and so do buildings and other obstructions including your own roof and house in directions of reception.
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or ' Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tuners will Automatic channel scan for cable tv channels.
Scan for channels.
Last edited by teleview; 14-Sep-2013 at 10:24 PM. Reason: Clarify information and typos.
mohu leaf ultimate, sky, trees
