Old 28-Aug-2013, 2:39 AM   #1
Helper monkey
How many stations can I get
http://www.tvfool.com/?option=com_wr...46ae64da6d9d77
Which antenna would you recomend for as many stations as possible. Roof mont
Helper monkey is offline   Reply With Quote
Old 28-Aug-2013, 8:36 PM   #2
The reception at your location is Weak Signal Strength , install a Big Antenna.
-->Many<-- channels will be received.
Above the roof in such a manner that the roof and house are not impeding and blocking reception in the directions of , South East , East.
Install a Winegard HD7084P All channel antenna aimed at about , 116 degree magnetic compass direction.
Use a Old School magnetic compass to aim antenna.
_______
Install a Winegard LNA-200 'Boost' XT amplifier.
_______
For 2 Tv's connected use a , Hollandelectronics , HFS-2D , 2 way splitter.
Buy the HFS splitters at sollidsignal.
_______
http://www.solidsignal.com.
http://www.amazon.com.
http://www.winegardirect.com.
http://www.ronard.com
_______
Here are some strong and sturdy antenna mounts.
Use the , ronard (911) 5 foot tripod antenna mount.
Use the , ronard (4560) eave antenna mount.
_______
As always , trees and tree leaves , plants and plant leaves , have a Negative effect on reception and so do buildings and other obstructions including your own roof and house.
The best practice is to install a antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
_______
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the , 'Air Channels' or ' Antenna Channels' , in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some digital tv's will Automatic channels scan for cable tv channels.
Scan for channels.
Last edited by teleview; 21-Sep-2013 at 6:59 PM. Reason: Clarify information and typos.
Old 29-Aug-2013, 1:21 AM   #3
elmo
The bigger, the better. But before we talk about that, how's the view of the horizon ESE of your home, from the roof? If you can see the sunrise, you're good. If you get lots of morning shade, trouble. Give us the scoop.
So for antenna, in general, big will capture as much signal as possible. It has to be full VHF/UHF. A decent medium directional antenna would probably do the job, but you could be marginal on some of the weaker stations on the list. Increasing the size boosts that in your favor.
Old 29-Aug-2013, 1:40 AM   #4
Helper monkey
Smile
Thanks Elmo
View to the ESE is clear
Old 18-Sep-2013, 3:15 AM   #5
Helper monkey
Talking
33 stations All Free!
Thanks everyone.
