Old 7-Jan-2013, 5:11 AM   #1
North Ga
new and need help deciding
I want to go through with the transition but I'm not sure my numbers look good enough to do so..Any and all advice appreciated..I have emailed a guy that does installatins but after I sent him my results I have not heard back. Thanks in advance and I love the site!
http://www.tvfool.com/?option=com_wr...c84f51a76cfe7e
North Ga is offline   Reply With Quote
Old 7-Jan-2013, 3:28 PM   #2
elmo
Some installer huh. I think anyone who wants a career in the service industry could make a good living by just returning calls!
There's a link on the forum for finding installers if you need help w/that.
Anyway, you can get plenty of stations easily. I'd look at an HD7000R, pointed south. An outdoor mount is best, with a view clear of trees and other large obstacles near by.
Old 7-Jan-2013, 3:29 PM   #3
Your numbers look fine.
A small UHF/high-VHF antenna facing Atlanta should do fine unless your really want that low-power analog broadcast of Azteca America.
Old 7-Jan-2013, 4:02 PM   #4
North Ga
thanks guys- I will look into finding a different installer.
Old 7-Jan-2013, 6:01 PM   #5
Many , many , many , Digital Tv channels will be received.
Above the roof in such a manner that the roof and house are not blocking reception in all directions install a Winegard HD7000R antenna aimed at about 173 degree magnetic compass direction.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html.
, http://www.ronard.com/ychim.html , http://www.ronard.com/34424560.html if using the eave mount use the #4560. , http://www.ronard.com.
Can also use a Winegard DS3000 J pole type antenna mount.
______________________________
No preamplifier is required.
Here are some places to buy antennas and etc. , http://www.winegarddirect.com , http://www.solidsignal.com , http://www.amazon.com.
_______________________________
As always , trees and tree leaves do a real fine job of , reflecting , reducing , blocking , Digital Tv reception and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7000R antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv/s Must Channel Scan for the Digital Broadcast Tv Channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Some Digital Tv's automatic channel scan for the cable tv channels.
Go into the Tv setup menu and select , 'Air Channels' / 'Antenna Channels'.
Old 7-Jan-2013, 8:20 PM   #6
North Ga
So..all antennas will pick up HD?? I looked up the HD7000r one sys it's HD and another has no mention of HD.
Old 7-Jan-2013, 8:26 PM   #7
North Ga
AntennaCraft HBU33 85 Boom HBU Series Antenna for UHF and High-Band VHF - 70 to 60 Mile Range
looking at this one..would I need an amp also?? sorry for the dumb questions but it appears I am on my own with the install, I can't find one in my area.
Old 7-Jan-2013, 9:17 PM   #8
Stereocraig
Any antenna that picks up the channel, will pick up HD.
HD antenna, is like saying color TV antenna,VS black and white or FM stereo antenna, VS FM mono.
Old 8-Jan-2013, 5:54 PM   #9
-->ALL<--> antennas are HD antennas.
Antennas made out of wire coat hangers are hd antennas.
A piece of wire is a hd antenna.
The human body is a hd antenna.
One part of Digital Broadcast and Digital reception is HD High Definition.
Here are the definitions/resolutions/clarity of the picture.
___________________
Low definition 480i. This is the Analog Broadcast and Reception that was transmitted for 70 years , when it was new , it was HD transmission and reception Television.
Now Digital processing is used to 'clean up' the 480i.
Improved definition 480P , as a reference point of clarity , Non HD - DVD's are 480P
High definition , Broadcast and Reception.
720P. As a point of reference , FOX transmits 720P as there HD picture.
1080i. This currently the highest definition for Broadcast Tv transmission and reception.
Tv stations can transmit 1080P , currently non are.
1080P. As a point of reference for clarity of the picture , Blue Ray is 1080P.
When Digital Broadcast Tv Transmission and Reception was new just a few years ago.
A popular topic on the Digital Tv forums was ,
Can you see any differences of clarity of the pictures of , 720P , 1080i , 1080P.
Old 20-Feb-2013, 7:48 PM   #10
North Ga
Well, I did it- and have been very happy with the results..The only channel I have trouble getting that I need is the NBC channel WXIA. For whatever reason it comes and goes..I believe it is as strong as the other major networks?? Any advice would be appreciated. I have tried amplifiers but they don't seem to make a difference, I have my antenna pointed south and slightly west... Over all I am very satisfied. Thanks in advance-
Old 20-Feb-2013, 8:14 PM   #11
What antenna is installed??
Where is the antenna installed??
Above the roof in such a manner that reception is not blocked in all directions by the roof and house??
Is the antenna in the attic??
Is the antenna down on the side of the house??
Is a amplifier being used now??
If so , what is the make and model number of the amplifier??
Old 20-Feb-2013, 10:44 PM   #12
elmo
Hmmm. So it's pointed in the right direction it sounds like. Any issues getting WGTV-PBS Ch 8? It's close to WXIA in distance, frequency. Can you also check the signal strengths on the TV for those?
To confirm, what antenna did you get - the HD7000R?
I wonder if someone will recommend an FM trap. I haven't used one that wasn't built into an amp, so I can't really say. But it often helps on VHF issues from what I understand. Only $5 at a Radio Shack, so worth a try, IMO.
Old 21-Feb-2013, 2:07 AM   #13
Dan4328
FM traps, in-line or in the amplifier, haven't helped for any of my two other previous locations in the Atlanta metro, even with Real 8 and 10 being near each other and the FM band.
If you want to go cheap, you can use a simple Terk 1080I/1080A antenna in the room of the TV as long as it points towards the Atlanta area. Since you live a reasonable 30 miles from Atlanta, you might want to use an attic antenna simply to avoid any chance of propagation interference. Make sure the antenna doesn't point too much over 190 degrees to prevent too much signal from WATC, which might interfere on the signal from the Atlanta channels.
If you have a portable digital TV, a simple one dipole antenna or rabbit ears will do if you need to use one, but I wouldn't recommend it for use all the time because of distance.
Dan4328 is offline   Reply With Quote
Old 21-Feb-2013, 2:13 PM   #14
North Ga
1. on the roof where my dish was..
2. yep
3. no
4. nope
5. no amp now but I have tried 2 different types
6. RCA amp/distributor, looks cheap..I also put an amp that had fm trap and signal booster, but can't remeber the make- I am not home at the moment
I adjusted the antenna yesterday slightly towards the east, and WXIA came up on my main t.v., our other tv still will not pick it up even after downloading the channels again.. I have adjusted the antenna a good bit just to see what I could pick up..towards the west I can get the Atlanta Channel but no WXIA, and slightly adjusted to the east, vica versa..I can live with that though..I will get the amp info up as soon as I get home.
Old 21-Feb-2013, 2:15 PM   #15
North Ga
the antenna is a 7 ft long wedge, vhf/uhf/fm
Old 21-Feb-2013, 2:16 PM   #16
Most importantly, WHICH antenna did you end up going with?
Old 21-Feb-2013, 2:21 PM   #17
North Ga
I don't know the name/brand..it was in my neighbor's attic, brand new and never used...to my knowledge it is a basic VHF/UHF/FM "wedge" antenna, with the V shape front and longer bars to the back..
Old 21-Feb-2013, 2:31 PM   #18
Sounds like a Radio Shack VU-90XR. Being so close to the roofline will hinder VHF reception quite a bit. Any chance you can go a bit higher?
Old 21-Feb-2013, 2:33 PM   #19
North Ga
that's what I was thinking next..I need to some how get higher I am only monted onto the dish mast at the moment..
Old 21-Feb-2013, 3:11 PM   #20
Most likely multipath.
Reflected signal off of trees and other objects , move the antenna to other locations as reception tests.
