Old 29-Nov-2012, 7:26 PM   #1
bigbadby
Unhappy Lost Channels Anomoly
I live in Kitchener, Ontario Canada N2M 3A4. I have an 18ft antenna. I have had success from the beginning with 3 cahnnels consistantly being recieved. I have continually scanned for add on channels on a regular basis with no luck untill I tried again the other day. It was about 9pm. It had been very foggy out that day and evening. To my delight I received 11 new channels which are now stored. Most came in very good. The next day I turned on the tv Only 2 new cannels came in so I adjusted the roar to receive one of the channels I really wanted. Now all the new channels no longer come in . What happened? How can I get them again?
bigbadby is offline   Reply With Quote
Old 29-Nov-2012, 7:39 PM   #2
elmo
Anomaly is right. Conditions are always fluctuating, and sometimes, you get some crazy reception just like you did. Then conditons revert back to their typical and it's gone.
Check this out that I posted not too long ago.
http://forum.tvfool.com/showthread.php?t=12698
Old 29-Nov-2012, 9:33 PM   #3
Please post the tvfool radar plot report.
http://forum.tvfool.com/showthread.php?t=4.
Use the Exact address to make the tvfool report.
Make the antenna height 25 feet.
What is the make and model number of the antenna??
Old 30-Nov-2012, 4:19 PM   #4
bigbadby
Talking Antenna Type
Thanks for your response. My anntenna is the LAVA HD2605 Ultra G3 Motorized Outdoor HDTV UHF/VHF Antenna with 20% More Gain. It is mounted on a pole (wood) on of the roof above the main entrance to my building. It is at least 18ft. I have done a signal report which was very helpful in locating Transmitter directions. My TV Fool Report is: http://www.tvfool.com/?option=com_wr...cc49900df52d05 . It seems that no matter how I rotate the antenna I just can't get back the new channels that I stored.
Thanks,
BigBadBy
Last edited by GroundUrMast; 30-Nov-2012 at 6:30 PM. Reason: Inserted TVFR based on redacted exact address. (protecting OP's privacy)
