Old 3-Jan-2013, 1:03 AM   #21
Re. the various sources of RFI:http://www.tvtechnology.com/conferen...visited/183659
Re. the various sources of RFI, FCC proposed solution (transmitter power level increases by 8 to 12 dB over the VHF spectrum {CH-13 through CH-2}) and the ongoing political pressure to take more spectrum from OTA TV:http://www.tvnewscheck.com/article/4...-high-priority
Old 3-Jan-2013, 1:05 AM   #22
Figure 3 and the related cometary are of help: http://www.broadcastpapers.com/white...E6988F127D1403
The implication of this work is that at the bottom of the Low-VHF band, noise levels can be as much as 30 dB higher than thermal noise level.
Old 26-Jul-2019, 11:40 PM   #23
This is an old thread, but the topic is still current because some channels are moving down to VHF-Low as a result of Repack by the FCC.
My measurements with indoor antennas show that the noise on channel 3 is 39 dB above the thermal noise floor (for a 6 MHz channel) and a channel 3 signal must be 33 dB stronger than a UHF channel.
Old 9-Aug-2019, 6:58 AM   #24
A quick but worthwhile read: http://www.hdtvexpert.com/tag/low-ba...-tv-reception/
Old 9-Aug-2019, 12:39 PM   #25
Good article; thanks for the link.
His noise level (-50 dBm) during a test was even higher than mine.
Pete Putman mentions KSNV on channel 2. In June of 2012 I tried to help a poster in Las Vegas who was having trouble receiving KSNV. I told him it was on VHF channel 2 (virtual 3.1), which it was at the time. He didn't believe me and said it couldn't be on 2.
https://www.avsforum.com/forum/25-hd...las-vegas.html
3.1 and 3.2 are digital UHF that I received LAST YEAR in my house a mile south of here with only Rabbit Ears on a ten foot pole, and now can't get them.
If they have gone back to using the vhf low freqs, that wouldn't make sense.
OTA includes both digital and analog channels !
The old VHF frequencies, especially 54 to 60 MHZ Is unusable for commercial TV now. Has been for eons because of six meters ham band which I use to work exclusively when I was a teenager and knew John The Baptist!
I quit! ! ! !
He is a ham and retired military commo guy who got so upset that I had to delete my earlier posts to him. After I had something to eat, I tried to explain it to him again.
