Old 11-Jan-2017, 5:06 AM   #1
mikebuild
Winegard HD7698P or HD8200U ?
Hey all,
The 7698 and 8200 are working well for a couple of friends down the road. Is one better than the other performance wise? Which one would you choose for:
http://www.tvfool.com/?option=com_wr...e6a4bcc5eb37d6
Or would you choose another?
Thanks
mikebuild is offline   Reply With Quote
Old 11-Jan-2017, 11:10 AM   #2
The 7698 is essentially an 8200 with the low-VHF elements eliminated. Since you have no low-VHF stations in your area, the low-VHF elements which make the 8200 so huge in the VHF section are superfluous for you. There is only a very small difference in the high VHF and UHF performance between the two models.
Old 10-Jun-2017, 7:29 AM   #3
Blackbeen
How would the 8200 UHF range compare to that of the HDB91X, I would think it would be worse & that I would need to use both for ultimate UHF reception though I would prefer a DB8E in combo but I'm ambivalent that the mast could handle the weight.
Blackbeen is offline   Reply With Quote
