Old 9-Mar-2016, 4:55 PM   #21
Originally Posted by drmenard View Post
There are two masts. At the peak of the roof there is a 4ft mast attached that is about one foot above the peak. At the top of it is the VHF antenna pointing at 22 [11] that don't move. Just below that on that mast there is a bearing mounted and at the bottom of that mast is the rotor. Then I have the second mast going threw the bearing and into the rotor. this mast is about 6 ft and at the top of it is the DB8e.
Bold type added that implies same location.
Semantics; two masts, one location.
The masts overlap.
Got it.
Maybe something like this:
http://www.ad5x.com/images/Articles/TB105.pdf
Old 9-Mar-2016, 5:30 PM   #22
tazz63
I'm missing something here, I just can't picture that.
tazz63 is offline   Reply With Quote
Old 9-Mar-2016, 9:10 PM   #23
tazz63
I see, but how does that work with the vhf antenna mounted on top of the short mast? I like the idea of the bearing, that makes a lot of sense for longevity and strength of the rotating mast.
Old 9-Mar-2016, 10:33 PM   #24
drmenard
That picture is what I have, I just have the lower mast up enough to put the VHF antenna.. I played with it today and I got 15 different stations and almost all of them have 2 or more channels.. The lowest station I got on the list was 19
drmenard is offline   Reply With Quote
Old 9-Mar-2016, 10:50 PM   #25
tazz63
Does the vhf antenna interfere with the other mast at all? It sounds like the mast would have to go through part of the vhf antenna
Old 9-Mar-2016, 10:51 PM   #26
tazz63
It's funny now everywhere I go I'm checking out rooftops and I'm seeing a bunch of antennas
Old 9-Mar-2016, 11:09 PM   #27
drmenard
I does not interfere at all , but the rotor mast is right next to it..
Old 10-Mar-2016, 12:09 AM   #28
tazz63
What are you using for a bearing?
Old 10-Mar-2016, 12:15 AM   #29
drmenard
It is a channel master, I got it at the time I bought the rotor.
Old 10-Mar-2016, 12:23 AM   #30
tazz63
I don't think they make that bearing anymore
Old 10-Mar-2016, 1:40 AM   #31
I think you are correct.
http://www.ebay.com/itm/CHANNEL-MAST...-/191562478065
