Old 10-Feb-2015, 9:40 PM   #1
JTl
Another reception question
Is it better to split the signal 3 ways at the ant vs using a 2-way and another 2-way down the line? I would like to hook up 3 tv's. I also have noticed that one of my tv's that is on the longest run has a problem with Fox, but if I hook up a different tv it works fine. http://www.tvfool.com/?option=com_wr...2c15a110ec8ff8
I am using this ant. Not sure if it is the best one to use.
I have cable but this is just for the tv's that only need the basic stations. ABC, NBC, CBS and Fox. I don't want to pay for a stb for each tv
JTl is offline   Reply With Quote
Old 10-Feb-2015, 10:00 PM   #2
It depends. Is it aimed at Ft Myers or at Riverview (TSP stations)? It should be fine for Ft Myers, but would greatly benefit from adding a VHF Kit ( https://www.antennasdirect.com/store/Reflectors.html ) for the TSP stations as a number of those are VHF.
It depends. It would likely be better to run a single coax down to your distribution point then install a balanced 3-way splitter there, but we don;t know how your cabling is currently laid out.
WHICH Fox station, there are two on your report.
Different tuners have different capabilities for handling semi-impaired signals. Some do okay, some do not as well.
Old 10-Feb-2015, 10:50 PM   #3
JTl
Aimed at Ft Myers. I need to come off the ant for one lead to a bedroom close by, then I have a long run 60', (2-way splitter, one to the bedroom and the other to the long run) to another point which is where I need to junction to two more tvs. As it turns out the "long run" is not getting anything now. Seems like the time of day makes a difference. I think I am just pushing the distance too much. The tv that is giving me fits has a run that is almost 100' from the ant. Thanks for your reply.
Old 11-Feb-2015, 3:24 AM   #4
How old is the C2 and how long has been installed in that location?
What is out in front of the antenna? Does it have a clear line of sight back towards Ft Myers?
Your signal analysis says you *should* have plenty of signal in the air at your location for plenty of splitters and coax. Therefore, there's something else wrong and it will require investigation.
Old 11-Feb-2015, 2:00 PM   #5
JTl
Thanks. There are some trees, but nothing real dense directly in front of the ant. I do get a very good signal except for one bedroom that is at the furthest point. I think it may be a cable issue in that room so i am going to replace it.
The C2 is about 3-4 years old as I recall.
