Old 11-Dec-2014, 8:07 PM   #1
Patrick
Freeport, TX area Antenna recommendation
Can you please offer some advice on an antenna to pick up the following stations from this area?
NBC – KPRC, Ch. 35
CBS – KHOU, Ch. 11.1
ABC – KTRK, Ch. 13
FOX – KRIV, Ch. 26.1
WB - KIAH, Ch. 39
This is for a business application and will require the signal to be split and distributed to 5 - Monitor/receivers with ATSC tuners that are approximately 100' feet away. We will be using Beldon RG6 Plenum cable to each monitor.
Report is here;
http://www.tvfool.com/?option=com_wr...d2437db3a42385
Thanks in advance for any help or advice you can offer!
Patrick
Patrick is offline   Reply With Quote
Old 11-Dec-2014, 8:39 PM   #2
I'd go with something like our ClearStream 2V aimed at Missouri city for starters.
You have plenty of signal according to your report, you can likely just use simple cable TV distribution splitter like this one: http://www.homedepot.com/p/CE-TECH-6...-204267325-_-N
If you need to, you can always add a preamp at a later date.
