Old 8-Apr-2014, 3:27 AM   #1
Battledad
Heyburn, Idaho
Father in law considering going to antenna. Appears signals come from multiple directions. Thoughts?
Battledad is offline   Reply With Quote
Old 8-Apr-2014, 3:33 AM   #2
Please review http://forum.tvfool.com/showthread.php?t=4 then post a link to your Father in law's TV Fool report.
Thanks
Old 8-Apr-2014, 3:54 AM   #3
Is this a , house , town home , condo , apartment , mobile home , motor home , or etc??
How many floors??
What is the top floor??
What directions do , windows , patios/balconies , face??
Use Exact address to make a Tvfool report.
Make the antenna height in the report , 25 feet.
A antenna height of 25 feet above ground is a reference antenna height that provides a good evaluation of what Tv stations are receivable.
Post the Tvfool report.
Old 8-Apr-2014, 6:15 PM   #4
Battledad
Sorry...was working from cell phone and now on the laptop.
Private residence. Single story. Antenna would be ~15 off the ground or so mounted to the side of the house. Front door faces north with the best mounting location being on the west side of the house.
http://www.tvfool.com/?option=com_wr...5b947934b24760
Old 8-Apr-2014, 9:46 PM   #5
StephanieS
Hi Battledad,
The good news is with this map, you have reliable access via translator to ABC, CBS, FOX and Idaho Public Television. NBC will be a little more work as there is no translator and you dealing with a 76 mile distance and a terrain obstructed signal.
What are your goals in over the air reception? Do you want all the big networks or is NBC not a big deal? Without NBC, the recommendation will become a little easier.
How is your immediate area? Are you surrounded by trees or do you have a open visibility to magnetic 120 and 60?
Cheers.
Old 8-Apr-2014, 11:28 PM   #6
To receive the Networks , and more.
NBC.
ABC.
CBS.
PBS , PBS Create , PBS World.
FOX.
MyNetwork.
CW and CW+.
This Tv.
RTV = Retro Tv Network.
Telemundo.
Will require a Antenna that can be aimed in two directions.
The antenna is a , Antennas Direct DB8e UHF antenna.
Above the Peak of the Roof install the DB8e so that 1 panel is aimed at about 127 degree magnetic compass direction.
Aim the other panel at about 227 degree magnetic compass direction.
Use a Real and Actual magnetic compass to aim antennas , do not trust a cell phone compass.
Buy the ronard antenna mounts at , http://www.ronard.com , or , http://www.amazon.com.
Home Depot has 10 foot 6 inch , 1 and 3/8 inch diameter , TOP RAIL , chain link fence , PIPE. that makes good antenna mast pipe , the price is low at about 10 dollars.
Install a , http://www.antennacraft.com.
10G201 preamplifier.
The FM radio interference trap of the preamp will be in the , in/on position.
For 4 Tv's connected use a , Holland Electronics , HFS-4D , 4 way splitter.
Buy the , HFS-2D and HFS-3D and HFS-4D , splitters at , http://www.hollandelectronics.com , or , http://www.amazon.com.
As always , the closer trees and other obstructions are in the directions of reception , the more disrupted reception will be.
As always , the more distant trees and other obstructions are in the directions of reception the better reception will be.
The Best Practice for Reliable Reception is to install the antenna at a location that has the least amount to no amount of obstructions in the directions of reception including your own roof and house.
Last edited by teleview; 9-Apr-2014 at 7:34 PM. Reason: Clarify information and typos.
Old 9-Apr-2014, 3:28 AM   #7
Battledad
He is using Dish and looking to see if he can max channel access. That would include the normal networks plus ion, me, this or others. When i look at the map i see the need for multiple antennas and then reception challe. Thinking he is best off with satellite.
