Old 15-Dec-2013, 4:16 PM   #1
Glate
Question Ota?
Recently stumbled upon this site and it got me thinking. Just wondering if there is a good antenna setup that is possible at my location. Here's my report:
http://www.tvfool.com/?option=com_wr...46ae5a65b19ed6
Just curious which channels are possible as well, not sure how to read the report!
Thanks in advance!
Glate is offline   Reply With Quote
Old 16-Dec-2013, 11:05 AM   #2
The tvfool report says , resolved to block level only.
For accurate reception information for making a antenna recommendation.
Please make and post 2 more tvfool reports using the Exact address to make the report and make the antenna heights 25 feet above ground and 40 feet above ground.
Do not delete the first tvfool block level report.
Old 16-Dec-2013, 8:20 PM   #3
Glate
I entered my address when asked but it apparently didn't like it... Here is a new report using the coordinates centred on my roof with Google maps.
25
http://www.tvfool.com/?option=com_wr...46aec79a02bdbe
40
http://www.tvfool.com/?option=com_wr...46ae9233598562
Old 17-Dec-2013, 3:40 AM   #4
Ok , little to no signal strength advantage of 40 feet antenna height.
Antenna System #1.
So at about 20 to 25 feet or so above ground , for reception of Digital Broadcast Tv stations/channels , to the North and North East.
The following are the North Group.
CHEK-DT , Real UHF channel 49 , virtual number (6.1) , Independent Tv.
CHAN-DT , Real UHF channel 22 , virtual number (8.1) , GTN.
CBUT-DT , Real UHF channel 43 , virtual number (2.1) , CBC.
CIVI-DT , Real UHF channel 17 , virtual number (17.1) , CTV2.
CIVT-DT , Real UHF channel 32 , virtual number (32.1) , CTV1.
CBUFT-DT , Real UHF channel 26 , virtual number (26.1) SRC French Tv.
The following are the North East Group.
KVOS-DT , Real UHF channel 35 , virtual number (12.1) , Me-Tv.
KBCB-DT , Real UHF channel 19 , virtual number (24.1) , Estrella Tv and a Shopping Network.
K24IC-D , Real UHF channel 24 , virtual number (28.1) KBTC PBS.
Above the Peak of the Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception to the , North and North East.
Install a Antennas Direct , DB8e UHF Bowtie Panel antenna aimed at about 0 degree magnetic compass direction.
Here is how to aim antenna , http://www.kyes.com/antenna/pointing/pointing.html.
Further antenna aiming , Think of your self standing behind the DB8e antenna looking out toward the Tv transmitters.
The Left 4 Bowtie panel is aimed at about 0 degree magnetic compass direction.
The Right 4 Bowtie panel is aimed at about 39 degree magnetic compass direction.
For 1 Tv connected Test reception with no antenna system amplifier
Use No splitter with 1 Tv connected.
____________________________________________________
Antenna systems 1 and 2 are Separate antenna systems all the way to the location of the Tv.
At the location of the Tv , connect antenna systems , 1 and 2 , to a Remote control A/B antenna switch and switch is then connected to the Tv.
Buy the Remote Control A/B Antenna Switch at , http://www.mcmelectronics.com. Part # 32-4425.
http://www.saveandreplay.com. Also has the same Remote Control A/B antenna switch.
Antenna system #2.
Also at about 20 to 25 feet or so above ground.
For reception of Digital Broadcast Tv stations/channels to the , South South East.
CHNU-DT Real UHF channel 21 , virtual number (21.1) , Religion Tv.
CKVU-DT Real UHF channel 27 , virtual number (27.1) , CITY TV.
CHNM-DT Real UHF channel 29 , virtual number (29.1) , OMNI 1.
CIVI-DT Real UHF channel 23 , virtual number (23.1) , CTV2.
K30FL-D Real UHF channel 30 , virtual number (7.1) , KIRO , CBS and RTV Retro Tv Network.
Install a Antennas Direct , DB8e UHF Bowtie Panel antenna above the Peak of the Roof in such a manner that the roof and building are not , obstructing , impeding , blocking , reception in the direction of , South South East.
Aim both panels of the DB8e antenna at about 178 degree magnetic compass direction.
For 1 Tv connected Test reception with No antenna system amplifier.
http://www.trentondistributors.com.
Use the , ronard (911) , 5 foot tripod antenna mount.
Use the , ronard (4560) , eave antenna mount.
Measure around the chimney and use a , ronard (2212) , ronard (2218) , ronard (2224) .
http://www.ronard.com.
The Best Practice is to install the antennas at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and building.
The Tv Must Channel scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the ~ DTV Channels ~ Broadcast Channels ~ Antenna Channels ~ Air Channels ~ in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable Tv channels.
Go in to the Tv Setup Menu and select ~ DTV Channels ~ Broadcast Channels ~ Antenna Channels ~ Air Channels ~.
Scan for channels.
Last edited by teleview; 18-Dec-2013 at 1:43 PM. Reason: Clarify information and typos.
Old 17-Dec-2013, 3:51 PM   #5
Glate
placement
How far apart should the two antennas be? Just wondering if I could put one on each side of my chimney (less holes into the roof to seal?) for example... I definitely expected it to be expensive but didn't anticipate $500 or more to get these 14 channels
Originally Posted by teleview View Post
Ok , no signal strength advantage of 40 feet antenna height.
Antenna System #1.
Antenna system #2.
Scan for channels.
Old 18-Dec-2013, 2:35 PM   #6
Yes can install one antenna on one side of chimney and other antenna on other side of chimney.
You can Test reception with 1 , DB8e antenna.
Aim one of the 4 Bowtie panels at about 10 degrees magnetic compass direction , a in between aim direction for reception of the , North Group and North East group at the Same time.
And aim the other 4 Bowtie panel at about 178 degree magnetic compass direction for reception of the South Group Tv stations.
One antenna with one coax down lead and No A/B switch.
If reception is weak and has drop outs on the weak Tv channels in the Red reception zone of the Tvfool report then install a Channel Master CM7778 preamp.
This one DB8e antenna with panels aimed different directions will most likely work , however I can not say 100% that it will.
A lot depends on avoiding local close trees and other obstructions in the directions of reception.
