Old 9-Feb-2013, 2:34 AM   #1
slonkoski
Antenna choice / diRection
Hi, like everyone sick of cable bills so cancelling. I have a stucco house so will probably end up with an outdoor antenna. I have a coat hanger special now in an upstairs window facing NE. I am getting 20 channels and get all local UHF channels so off to a good start. I'd like to get ABC WTNH which is VHF and any other channels, what antenna would you suggest and am I correct in assuming I should put it on the roof? Which direction to point it?
http://www.tvfool.com/?option=com_wr...1ddac0d47fc29a
Thanks
slonkoski is offline   Reply With Quote
Old 9-Feb-2013, 7:25 AM   #2
Above the Peak of the roof install a Winegard HD7696P antenna with a Winegard HDP-269 preamp in such a manner that the reception is not blocked by the roof and house in the directions of , north east , east , south east , south.
Aim the HD7696P antenna at about 170 degree magnetic compass direction.
________________________
http://www.ronard.com/909911.html , if using a tripod antenna mount use a 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html , if using a eave antenna mount use the #4560.
http://www.ronard.com/ychim.html , http://www.ronard.com.
__________________________
______________
Buy the HFS splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
__________
As always , trees and tree leaves do a good job of , reflecting , reducing , blocking , OTA=Over The Air , Digital Broadcast Tv stations/channels reception and so do buildings and other obstructions including your own roof and house.
It is best to install the HD7696P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
____________
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Tv Setup Menu and select , 'Air Channels' / 'Antenna Channels'.
Old 10-Feb-2013, 1:46 AM   #3
slonkoski
Thank you. Time to ship as soon as the three feet of snow melt and I can get up to roof.
Old 25-Feb-2013, 12:54 PM   #4
slonkoski
I ended up getting a Clearstream 2CV, mounted under eave above lower roof line, I get one more channel than with the coathanger special, oh well. Pointing about 110 degrees for now. Maybe in spring I'll pick up the large Winegard and do a chimney mount with rotator, but I'm pretty happy with current channels.
Old 25-Feb-2013, 4:20 PM   #5
elmo
Did you get WTNH at 110 degrees? I'd suspect not, as it's just past 180, so you're about 90 degrees from it. Reception from the side of the CS2 will be weak. You need at least another 45 degrees south to get a decent signal, from what I can tell.
Old 25-Feb-2013, 5:28 PM   #6
When it is time to move the antenna.
The antenna Must Be UP High above the High Point of The Roof so that the roof and house are not blocking reception.
Some of the Tv stations are Weak Signal Strength and require a clear shot for the best reception.
Because you have the CS2V antenna now.
Install the CS2V above the roof with the HDP-269 preamp.
Aim the CS2V antenna at about 170 degree magnetic compass direction.
These are the Digital Tv stations/channels and sub channels you are reaching out for.
WFSB , REAL UHF Digital channel 33 , virtual number (x) , CBS.
WTIC-TV , REAL UHF Digital channel 31 , virtual number (61.1-2) , FOX and Antenna Tv.
WUVN-DT , REAL UHF Digital channel 46 , virtual number (18.1) , Univision.
WEDH-DT , REAL UHF Digital channel 45 , virtual number (x) , PBS.
WCCT-TV , REAL UHF Digital channel 20 , virtual number (x) , CW and This Tv.
WVIT-DT REAL UHF Digital channel 35 , virtual number (30.1-2) NBC and Cozi Tv.
WRDM-CD REAL UHF Digital channel 19 , virtual number (x) , Telemundo.
WTNH-DT REAL VHF Digital channel 10 , virtual number (8.1) , ABC.
WRTN-LP REAL UHF Digital channel 48 , virtual number (48.1-2-3-4) , RTV and Cozi Tv and Tuff Tv and Classic Movies.
WZME REAL UHF Digital channel 42 , virtual number (x) , Me-Tv and RTV.
WCTX-DT REAL UHF Digital channel 39 , virtual number (59.1) MyNetwork.
These tv stations should be received with one antenna , without rotating the antenna.
(((( It is -->Very Important <-- to install the CS2V antenna In The Clear for reception of the Tv stations to the , south east , south , south west. WTHN , WRTN , WZME , WCTX , are Weak signal strength at your location. ))))
---->Do not underestimate the Desire that Trees have to , reflect , absorb , block , Digital broadcast Tv reception.<----
Tv antenna rotators Are Not channel surfing friendly , must wait for antenna to rotate and their Will Be Domestic Situations about the direction the antenna is aimed.
The other receivable Digital Tv stations are to the , north east.
The Tv stations are.
WWLP , NBC.
WGGB , ABC and Fox and MyNetwork.
WGYB , PBS.
The Tv stations to the , south east , south , south west , have All those Networks. NBC , ABC , Fox , MYNetwork , PBS.
