Old 12-Sep-2012, 11:32 PM   #1
Langland
What Antenna would you recommend
http://www.tvfool.com/?option=com_wr...5ed6035e4e6d28
That's my location hopefully it works. The area is Shell Lake Wisconsin and I want to get the channels in Eau Claire primarily so I can get news from a Wisconsin based news station since the Minnesota ones don;t really report anything. I kind of also want to watch Packer Games and also know what's happening my state for once since once again Minnesota's stations don't report any Wisconsin news and if they do it's very rare.
So I see the WEUX is about 57 miles away and the WQOW is like 71. I personally would like to know what Antenna to look into getting and what other stuff maybe needed. I will gladly put the work in if I can help it to get the channels.
Langland is offline   Reply With Quote
Old 13-Sep-2012, 1:52 AM   #2
The following is a Teleview recommendation for broadcast Tv reception.
The tvfool report is at street level only and might not represent a accurate picture of the reception at your location.
The Digital Tv stations/channels are Very Weak.
WEUX and WQOW are not receivable at the street level at 30 feet antenna height.
It is Important to make a accurate tvfool radar report.
To make a accurate tvfool report , go to the tvfool home page and click on >>Start MAPS<< , move the pointer to your location and make a tvfool radar plot map.
Be sure and enter in the 30 foot antenna height.
Also please make 2 more tvfool radar plot maps at 40 and 60 feet to see what signal strengths are at those antenna heights.
Old 13-Sep-2012, 10:18 PM   #3
Langland
http://www.tvfool.com/?option=com_wrapper&Itemid=90
Ok I did that and It says at 40 and 60 feet that WEUX can come in since it's 59.2 miles away. before this whole DTV switchover I could get the Superior/Duluth Stations quite fine on Analog and now it's saying those would be weak.
So that's kind of where I got my assumption if I aimed at Eau Claire maybe they would come in since it's roughly the same distance and the same amount of trees and stuff interfering.
Old 13-Sep-2012, 11:03 PM   #4
The link is not working , Send me a PM private message with your Exact address and or cordinates and I will make and post the tvfool radar reports for you.
Old 13-Sep-2012, 11:11 PM   #5
Langland
ok done it
Old 14-Sep-2012, 7:13 AM   #6
These tvfool radar plot reports are the provided address.
30 feet.
http://www.tvfool.com/?option=com_wr...5ed65522d715a0.
40 feet.
http://www.tvfool.com/?option=com_wr...5ed69d02b505d0.
60 feet.
http://www.tvfool.com/?option=com_wr...5ed652c7e1b9c5.
100 feet.
http://www.tvfool.com/?option=com_wr...5ed6db93d6dea2.
______________________________________________________________
The following Digital Tv stations/channels are receivable.
W24CL-D REAL UHF channel 24 and WHWC-DT REAL UHF channel 27 , are both the same PBS and Wisconsin Channel and Create.
http://en.wikipedia.org/wiki/WHWC-TV.
WDIO-DT REAL VHF channel 10 ABC and ME-TV.
http://en.wikipedia.org/wiki/WDIO-DT.
WDSE-DT REAL VHF channel 8 PBS and Minnesota Channel and Create.
http://en.wikipedia.org/wiki/WDSE-TV.
KQDS-DT REAL UHF channel 17 FOX.
http://en.wikipedia.org/wiki/KQDS-TV.
KBJR-DT REAL UHF channel 19 NBC and MyTv Network.
http://en.wikipedia.org/wiki/KBJR-TV.
KDLH-DT REAL UHF channel 33 CBS and CW.
http://en.wikipedia.org/wiki/KDLH-TV.
The next 2 are likely not receivable. However you can try.
WEUX-DT REAL UHF channel 49 FOX.
http://en.wikipedia.org/wiki/WEUX-TV.
WQOW-TV REAL UHF channel 15 ABC.
http://en.wikipedia.org/wiki/WQOW-TV.
Old 14-Sep-2012, 8:54 AM   #7
Antenna system number 1.
At 60 feet antenna height , install a Winegard HD7698P antenna with a KitzTech Ultra Low Noise , KT-200VG-COAX TV Antenna Booster.
For reception of the of the group of broadcast tv stations/channel to the north at about 355 degree magnetic compass direction.
________________________________________________________________
Antenna system number 2.
At 60 feet antenna height.
For reception of Wisconsin PBS , UHF channel 27 , aim a Winegard HD9095P antenna with a KT-200VG-COAX TV Antenna Booster , at about 170 degree magnetic compass direction.
WEUX and WQOW are the same direction.
Antenna systems numbers 1 and 2 are Not connected together on to one coax.
The 2 separate antenna systems are separate all the way to the location of the Tv , and the 2 separate coaxes are connected to a Remote control A/B antenna switch. http://www.radioshack.com , #15-1968 , or , http://www.mcmelectronics.com , #32-4425 .
Depending on how high the roof is.
Here are some ways to get the antennas 60 feet in the air.
http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com/Tripods%200703/4712.html , http://www.ronard.com.
Buy the ronard antenna mount at soldsignal by typing the word ronard in the solidsignal search box.
Here are some places to buy antennas and etc. , http://www.soldsignal.com , http://www.amazon.com , http://www.winegarddirect.com , http://www.kitztech.com
Old 14-Sep-2012, 9:06 AM   #8
Here are 2 more ways to get the antennas in the air.
http://www.3starinc.com/telescopic_masts_and_more.html.
Light weight aluminum layover tower , install and adjust antennas standing on the ground. http://www.palcoelectronics.com/pe300.aspx.
___________
Yes it is Ok to 'test' reception at , say , about 40 feet antenna height.
