Old 13-Mar-2012, 7:16 PM   #1
linuxmant
How good are these antennas
Hello, I was looking at this antenna: Channel Master CM3010
and i started wandering if it would work in te attic for this location:
http://www.tvfool.com/?option=com_wr...0b8647e364d123
Are there any indoors recommended instead?
I also found some of the (antennaHub) AX-9xx models (969, 909g2.3, 912) with good reviews, but a bit pricier... what do you guys think about these too?
Thanks in advance
linuxmant is offline   Reply With Quote
Old 13-Mar-2012, 9:10 PM   #2
Tv antennas and Tv reception
The cheap china junk antennas have been dealt with many times here a tvfool. Do Not buy the cheap china junk antennas.
Old 13-Mar-2012, 9:44 PM   #3
If the house is wood frame with wood or vinyl siding , then a NON AMPLIFIED indoor antenna such as the Channel Master CM4010 or Terk HDTVi indoor antenna aimed at about 104 degree magnetic compass. Pull the rods of the indoor antenna all the way out and have the rods of the antenna in a low V <- lower then this V. Do not have the rods of the indoor antenna straight up like this , ||. If the house is , concrete , concrete blocks , cinder blocks , brick from ground to roof , big rocks for walls , stucko and stucko Wire , metal roof , metal foil backed insulation , solar panels , the antenna is put in the basement , then reception will be reduced using a indoor. For your reception situation. A better outside Roof Top antenna is the RCA ANT751 antenna or a Antenna Craft HBU22 antenna. Here are some places to buy antennas and etc. , http://www.channelmasterstore.com , http://www.antennacraft.net , http://www.amazon.com , http://www.ramelectronics.com , http://www.tigerdirect.com , http://www.solidsignal.com . Here are some roof top antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com. buy the ronard mounts from solidsignal by typing the word ronard in the solidsignal search box or buy from ronard.
Old 13-Mar-2012, 9:51 PM   #4
Here is how to aim indoor and outdoor antennas , http://www.kyes.com/antenna/pointing/pointing.html
Old 13-Mar-2012, 10:12 PM   #5
linuxmant
Thanks for the info...
I'll check all this out.
Old 13-Mar-2012, 10:16 PM   #6
I see that , http://www.digicircle.com , has very low price on the HBU22. Orders at digicircle need to be placed on line with your computer or you can go to the store and use a computer in the lobby and then pick up the antenna at the same store in California. Yes I know it's a strange way to do business but thats the way they do it. Yes the merchandise they sell can be shipped. Type the word - antennas - in the search box at digicircle.
