Old 6-Mar-2012, 7:14 PM   #1
natalie3895
Need Advice Just Bought Channel Master CM 3016 and here is Analysis
http://www.tvfool.com/?option=com_wr...0b863a690847a3
natalie3895 is offline   Reply With Quote
Old 7-Mar-2012, 7:17 AM   #2
Tv antennas and Tv reception
Install the CM3016 antenna above the roof aimed at 187 degree magnetic compass , 178 degree true. Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html. Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com, Buy the antenna mounts from , http://www.solidsignal.com , by the ronard antenna mounts by typing the word - ronard - in the solidsignal search box or buy from ronard.
Old 7-Mar-2012, 7:21 AM   #3
No antenna amplifier will be needed for one or two Tv's connected. Use a simple common 2 way splitter for 2 Tv's. Use No splitter if one tv is connected. How many Tv's are/will be connected??
Old 9-Mar-2012, 6:02 PM   #4
natalie3895
Yes thanks so much....im just going to use one tv as of right now
Old 9-Mar-2012, 6:17 PM   #5
natalie3895
another question?
ill be moving into a community with an HOA...can they prevent me from installing it?
Old 9-Mar-2012, 10:44 PM   #6
Here is the Federal Law that says Yes you can install and use a antenna above the roof. The hoa's are Well Aware of this Federal Law yet some hoa's will try and scam people in to believing that they can not have a antenna above the roof. Some hoa's will try and use scam ideas , like you have hide the antenna or it must be a small antenna or you must put the antenna in the attic or you are bad person if you have a antenna. Some hoa's will play on other peoples fear to put pressure on you and scam you. . Hoa's Can Not Prevent or Even Delay you from installing a antenna. This Is Federal Law - Settled Law - it has been challenged many times in court , (before you came along and asked the question) and the , hoa's , housing coven-nuts , cities , counties , states , and all other crazies have Lost time after time in court. http://www.fcc.gov/mb/facts/otard.html . Read what I said about antennas and the Federal Law at this question askers post , http://forum.tvfool.com/showthread.php?t=7188
