Old 12-Jul-2011, 9:47 PM   #1
wihardware
Smile Central Wis reception
I have to replace my antenna and pre-amp. Currently I get the Wausau market, green bay and some of the Madison market. I'm going from 30' to 60' and have ~ 100 ft of RG-6 . I will be feeding 4 tunners. Do I need a distribution amp as well as a Pre-amp? My tvfool report is http://www.tvfool.com/?option=com_wr...03d97043830a61 .
Any advise would be appreciated as I only want to do this once.
Yes there is also a rotor.
wihardware is offline   Reply With Quote
Old 14-Jul-2011, 2:47 AM   #2
Please make a radar plot with the antenna height at 25 feet. So I can see if the signal strengths drop that much.
Old 14-Jul-2011, 3:44 AM   #3
wihardware
25 ft plot
John,
The 25ft plot can be found at: http://www.tvfool.com/?option=com_wr...03d9ec5c9a9cf5
If you have any questions I will try to answer them
Stuart
Old 14-Jul-2011, 10:09 AM   #4
I recommed a Winegard HD7698P antenna and Winegard HDP269 preamp. Connected to a Channel Master CM3414 , 4 way distribution amplifier. I would recommend trying the 30 foot antenna height first and see if you will receive all the channels you will like to watch.
Old 14-Jul-2011, 10:41 AM   #5
At 60 feet there is a small improvement in the weaker channels , as an example WGBA-TV 41 NBC , goes from -3.9 NM(dB) at 25 feet to -0.2 NM(dB) at 60 feet , and the stronger stations at the top go from the yellow zone to the green zone. It is border line improvement. Is it worth going to 60 feet to get it ?? Well thats your decision. I recommend trying at 30 feet first.
Old 18-Jul-2011, 8:53 PM   #6
Read and understand about , REAL Digital Broadcast Tv Channels , Virtual Digital Broadcast Tv Channels , Analog Broadcast Tv Channels , http://forum.tvfool.com/showthread.php?t=695
Old 19-Jul-2011, 2:38 AM   #7
Two amplifiers in the same system will add noise and distortion unnecessarily, I'd opt for a single pre-amp, such as the Antennas Direct CPA-19.
An FM trap may be needed.
