Old 23-Mar-2011, 6:22 AM   #1
stiksandstones
choosing my HD antenna
Here is a link to my report....
I just ordered this stuff, will it work?
link:
http://www.tvfool.com/?option=com_wr...8d17a64913ebde
Stuff:
A Winegard TA-1713 VHF high-band yagi plus
an AntennasDirect XG-91 mounted on the same mast, with the XG-91 mounted 4' above the YA-1713 on the mast. Combine the two antennas using a Channel Master Titan 7777 preamplifier
stiksandstones is offline   Reply With Quote
Old 23-Mar-2011, 1:49 PM   #2
No static at all
No static at all's Avatar
You should do well with the LA stations. The 7777 preamp may cause issues with some of the weaker stations though. I would probably have chosen the more tolerant Winegard 2870 instead of the 7777. I would also try without the preamp first to see what you get connected to just 1 TV & take it from there.
Old 23-Mar-2011, 3:19 PM   #3
It looks good to me. The stronger stations are off axis, so the 7777 should be OK.
Old 3-Apr-2011, 11:00 PM   #4
stiksandstones
so when I put up these 2 antennas...do I point them in a certain direction?
Old 3-Apr-2011, 11:48 PM   #5
302° compass appears to be the big group.
