Old 21-Sep-2019, 6:54 PM   #1
jerrymc
KDOC Not in TVFool Database?
Why is KDOC in Los Angeles missing in the TVFool database?
It's clearly broadcasting and has been for many years.
HD8200XL and HDB91X with RCA TVPRAMP1R pre-amp aimed at Mt. Wilson (Los Angeles) in Etiwanda area.
CM3410 dist. amp in attic for a 5 room hookup.
Located in foothills behind Mt. Baldy, and experiencing signal loss and pixelation depending on time of day.
Using RCA rotator motor now to tweak.
Location Radar
jerrymc is offline   Reply With Quote
Old 21-Sep-2019, 9:31 PM   #2
OTAFAN
Hi jerrymc:
TV Fool has a very small staff that has not been able to keep up with Repack changes, etc. But, I just checked Rabbitears.info for the LA Market and it's there. Copy and past (sorry I'm not the most adept computer keystroke). Hope this helps.....
56
12
KDOC-TV
ANAHEIM
CA
IND
Display
Channel
Physical
Channel
Video
Audio
Call Sign
Network/Programming
Nickname
Notes
Print
56-01
12.1
720p
DD2.0
KDOC
Independent
"KDOC"
56-02
12.2
480i
DD2.0
ESNE
ESNE TV
56-03
12.3
480i (w)
DD2.0
Me-TV
Me-TV
"Me-TV Hollywood"
(KHTV-CD 54-1)
56-04
12.4
480i (w)
DD2.0
Comet
Comet TV
56-05
12.5
480i
DD2.0
SETTV
SBTN
56-06
12.6
480i (w)
DD2.0
KDHL-TV
Vietnamese
56-07
12.7
480i
DD2.0
LSTV
Vietnamese
"Little Saigon TV"
56-08
12.8
480i (w)
DD2.0
CHARGE
Charge!
56-09
12.9
480i (w)
DD2.0
CHTV
Chinese
"Christian Herald Television"
56-10
12.10
480i (w)
DD2.0
VGMT
[Blank]
Technical Data
Ownership, Repack, Historical, and Translator Data
Old 21-Sep-2019, 10:43 PM   #3
jerrymc
Kdoc (h-vhf)
Thanks.
I didn't realize KDOC moved to H-VHF (207MHz) a few months ago when KTLA moved its freq. as well.
It now makes sense that KDOC doesn't come in as well anymore, along with KABC (177MHz). So much for using 2 separate antennas.
(One for UHF and one for VHF.)
Location Radar
Old 21-Sep-2019, 11:56 PM   #4
OTAFAN
Hi jerrymc:
Yes, and for those of us who have been a bit frustrated with their previous signal strength on their UHF frequency, this change to VHF High 12, physical, with strong readings on my TV meter, 35dB plus SNR, was a welcome boon. No complaints from this Peanut Gallery since the change!
Sorry to hear about your difficulties due to your location. If you send a PM (for your privacy) to rabbit73, he has the technical background to run a location check that might help with your reception. At least it couldn't hurt and only cost you in a small amount of time. Just an idea.
Anyway, hopefully better viewing days ahead for you. All the best.....
Old 22-Sep-2019, 2:28 AM   #5
KDOC moved from 32 to 12 during Repack Phase 2
https://www.rabbitears.info/market.p...&callsign=KDOC
Repack Plan
Current TVFool report:
http://www.tvfool.com/?option=com_wr...90385d21dbceed
Report from rabbitears.info, which should be more accurate:
https://www.rabbitears.info/searchma...study_id=13545
Extract from rabbitears.info report:
You are behind a mountain for KDOC, jerry:
Your location is on the edge of the red zone of the Longley-Rice coverage map, which is the weakest listed signal strength.
Because of the directional KDOC transmitting antenna pattern, less than 38 kW out of 110 kW ERP is sent in your direction:
