Go Back   TV Fool > Over The Air Services > Special Topics > Digital TV and Mobile DTV
Old 5-Jun-2017, 4:36 PM   #21
Not sure what you mean by a power inserter
The power inserter is part of the preamp system. It makes it possible to send the DC power up to the preamp AND send the signals down to the TV on the same coax line.
https://www.channelmaster.com/TV_Ant..._p/cm-7777.htm
manual
http://downloads.channelmaster.com/S...77_7778_UG.pdf
I am running the original coax that was here from the 80's. Does that make a difference?
Yes, it can make a big difference. Old coax can go bad from corrosion. It could be the reason why your neighbors are doing better than you are.
As for the preamp and antenna suggestion, what can I expect from this combo compared to what I have?
It might make it possible to receive WQPX, but it will never be 100%. Just an experiment, no guarantee.
Try the new coax first.
Old 5-Jun-2017, 5:57 PM   #22
urhstry
Send a message via AIM to urhstry Send a message via Yahoo to urhstry
I have new coax laying around, I may try that today. As for the power inserter, yes I have that, came with the cm-7777.
urhstry is offline   Reply With Quote
Old 5-Jun-2017, 6:00 PM   #23
JoeAZ
Just an observation. It might be costly and time consuming
to TRY and receive WQPX and it might never happen reliably,
if at all. According to Wikipedia, there are six subchannels,
most of which aren't anything special. You might be better
off just streaming a few additional programs to your current
tv......
Old 5-Jun-2017, 6:43 PM   #24
urhstry
Yeah I was looking at that too but I want to try to get the absolute best reception I can get..... its a challenge now. Plus by getting that one channel I also pick up channel 31 which is 3 more channels.
Old 6-Jun-2017, 12:30 AM   #25
Maybe, it's not possible to accurately predict what will or won't be received with signal estimates as low as yours.
All you can do is try it and see what happens.
