Old 9-Jan-2016, 5:40 PM   #21
welkin
I have the new 7777.
ADTech,
I'm not quite clear on the instructions of the 91XG. What is the correct way to run the coax?
Thanks
welkin is offline   Reply With Quote
Old 9-Jan-2016, 6:14 PM   #22
Whatever works. Free-form it. The routing of the coax isn't critical to the reception capabilities of the antenna, so just secure it so it doesn't whip around in the wind.
Old 18-Jan-2016, 4:09 PM   #23
welkin
Hello all,
I have attached pictures of testing the setup this weekend. I ended up going a totally different direction than when I wanted to mount the 2-HD8200Us.
Every channel is coming in loud and clear with the exception of KOMU. KOMU is showing some artifacts, but I'm hoping it will clear up once I get everything up on the 30' mast. As you can see, I am surrounded by trees and will probably need to go higher by spring.
Thank you ADTech and rabbit73 for your guidance.
