Old 12-Oct-2013, 12:21 PM   #1
WhoseTARDIS
Antenna advice
Hello, I need some suggestions for antennas. ABC, FOX, NBC and CBS have a tower on Wopsy Mt above Altoona, so these channels I should be able to receive with a good antenna. What kind of antenna do you all think I would need for PBS stations (WPSU) North of me? Thanks
http://www.tvfool.com/?option=com_wr...46ae88435335d4
WhoseTARDIS is offline   Reply With Quote
Old 12-Oct-2013, 9:24 PM   #2
Those are some tough reception conditions.
'Go big or go home' applies in this case. You'll need to mount a large UHF antenna above or clear of trees and nearby buildings.
I would consider the Antennas Direct 91XG or DB8e or perhaps the Winegard HD9095P.
An Antennas Direct PA-18 preamp would also be needed.
Then, you'll need to consider a rotator.
Old 12-Oct-2013, 11:29 PM   #3
Practical and Useful Information.
For reception of ,
WHVL-LD Real UHF channel 27 , MyNetwork and America 1.
WPSU-TV Real UHF channel 15 , PBS channels.
WTAJ-DT Real UHF channel 32 , CBS.
WATM-DT Real UHF channel 24 , ABC and FOX and This Tv.
Aim a Channel Master CM4228HD at about 15 degree magnetic compass direction.
Install a CM7778 preamp.
For reception of ,
WJAC-TV Real UHF channel 29 , NBC and Me-Tv.
Install a second antenna and amplifier that is the same as the first antenna and amplifier.
Aim at about 280 degree magnetic compass direction.
The 2 antennas systems Are Not connected together on to 1 coax.
The 2 antenna systems are separate antenna systems all the way to the Tv location/s.
A Remote control A/B antenna switch is used to change antennas.
www.mcmelectronics.com
Part number 32-4425.
www.soildsignal.com
www.amazon.com
www.channelmasterstore.com
A antenna rotator is not required.
Last edited by teleview; 13-Oct-2013 at 12:35 AM. Reason: Clarify information and typos.
Old 13-Oct-2013, 1:40 AM   #4
WhoseTARDIS
Thanks for the help! I knew this would be a tough job to receive these channels. Glad I have the internet for Netflix and Amazon Prime on the Roku box. This will save me a hundred dollars a month! Any suggestions on a stand alone DVR?
Old 13-Oct-2013, 1:47 AM   #5
WhoseTARDIS
How high can I go with my antenna, without using guy wires? I plan on installing some sort of pole in the ground like a 16' 4x4, but not sure what kind of mast or how far above the pole I can go.
Old 13-Oct-2013, 4:39 AM   #6
Pratic and Useful Information.
www.ronard.com/909911.html
www.ronard.com/Tripods%200703/4712.html
10 foot tripod antenna tower.
www.ronard.com/ychim.html
Measure around the chimney and use a , ronard(2212) , ronard(2218) , ronard(2224) , chimney antenna mount.
Can go 10 feet above mounts with no guywires.
Here are , Free Standing , No Guywires , Lay Over , Aluminum , Towers , Do antennas installation and adjustments standing on the ground.
www.palcoelectronics.com
Last edited by teleview; 13-Oct-2013 at 4:59 AM. Reason: Clarify infoation and typos.
