Old 3-Jul-2013, 7:15 PM   #1
bzzy
Best Antenna for Basement
Hi. I have an HDTV in our basement. We are currently using a TERK Omni Directional Amplified Antenna - Model #FDTV2A Digital Pro. We keep losing reception or when we do get reception...we don't get all of the channels. It sits in a window that has a small evergreen tree about 2 ft away and the antenna faces northeast. Short of having to install an outside rooftop antenna...is there anything we can do?
Thanks for your help!
bzzy is offline   Reply With Quote
Old 3-Jul-2013, 8:21 PM   #2
Please, do yourself a favor and move the antenna out of the basement.
Old 3-Jul-2013, 9:03 PM   #3
As you Now Know.
The Basement is Not a Good Place for a Broadcast Tv antenna and Broadcast Tv reception.
The Earth and the Building Down In The Ground , does a Excellent Job of Blocking Broadcast Tv reception.
As always , trees and tree leaves , plants and plant leaves , have a Negative effect on Broadcast Tv reception with a Tv antenna.
___________________
So that the helpers here at tvfool can be of some real and useful help.
_________
Is this a , house , town home , condo , apartment , mobile home , motor home , or , etc.??
Why do you have a Tv antenna in the basement??
What directions do , windows , patios , balconies , face??
What floor??
What is the top floor??
____
Please make and post a tvfool radar plot map and channel list.
Use the Exact address to make a tvfool radar map plot and channel list.
Make the antenna height 25 feet above ground , 25 feet is a Reference antenna height number so the helpers here at tvfool can see what is available for your reception location.
__________________________
Last edited by teleview; 4-Jul-2013 at 4:28 AM. Reason: Clarify information and typos.
Old 3-Jul-2013, 10:23 PM   #4
bzzy
Unhappy
So you're suggesting that I get a roof top antenna....ok...but what kind do I need?
Thanks!
