Old 28-Feb-2011, 12:47 AM   #1
samanova
Need help in GA after ditching Dish
I'm trying to go through all the reviews on antennas and it seems there is no right one....depending on location.
I am trying to find something I can do myself without a pole and put in the attic of a single story home. I have a short range one up there now with a pre amp between the TV and the co-ax cable. It works...just okay. I can pick up Fox, PCH and sometimes ABC....and some other random stuff
Is there any hope?
here's my chart:
http://www.tvfool.com/?option=com_wr...c77a2a623e0d2e
Thanks for any advice!
samanova is offline   Reply With Quote
Old 28-Feb-2011, 6:03 AM   #2
Yes, there is hope...
A 'do-it-yourself' size antenna such as the RCA ANT-751 can mount on the side of the house. My preference would be a larger antenna, up high... but the smaller antenna should give you a solid lineup of programing when mounted outside, aimed at about 140° per your compass.
Attic mounting can/will rob you of a surprising amount of signal.
Old 28-Feb-2011, 1:21 PM   #3
samanova
Thanks GroundUrMast
That one just may fit the budget too!
The Dish is still on the roof so maybe I can attach to the existing hardware and use the co-ax from that as well. It looks small enough so hopefully the homeowner's assoc won't pitch a fit
Old 28-Feb-2011, 6:08 PM   #4
FWIW: The FCC says you can place an antenna on your roof... http://www.fcc.gov/mb/facts/otard.html Your HOA will most certainly know this, though I doubt they are willing to be the ones to tell you.
The J-pole used to mount your dish makes an excellent mast for the small and mid-size antennas. When aiming south (generally), an existing J-pole is usually mounted in a convenient spot. The coax from you satellite installation is compatible with OTA reception, though many of the other components will not be.
