Old 15-Aug-2013, 11:11 AM   #1
macmansc
Antenna Choice for Rural Area between 2 cities
Here's my location.http://www.tvfool.com/?option=com_wr...46aefa8a8728e8
I had purchased this antenna a little over 2 years ago. http://www.amazon.com/Sewell-Direct-...direct+antenna
I got about 18 channels with it, and it picked up well enough never to need the rotator. However, it's approaching my second anniversary of cutting the cord and I need an upgrade (mainly because the amp went out).
Which should do the trick the ChannelMaster 4228HD or Clearstream C4. Should I use the CM7777 preamp with each? I put a Clearstream C2 with no amp, but it didn't fair too well.
This will be an attic install.
macmansc is offline   Reply With Quote
Old 15-Aug-2013, 5:58 PM   #2
As always , attics and the inside of buildings Are Not a reception friendly environment and Never Will Be a reception friendly environment.
Reasons:
Multi-Path/Reflections , signals bouncing around.
Absorbing Tv reception.
Blocking Tv reception.
___________________
Install the Channel Master CM4228HD in the attic aimed at about 210 degree magnetic compass direction.
______________
If required for better reception , install a CM7778 preamp.
______________
As a Test of reception of both the Columbia and Charlotte Tv stations at the same time with one CM4228HD antenna.
Above the Peak Of The Roof in such a manner that the roof and building are not impeding and blocking reception in the directions of Columbia and Charlotte.
Install the CM4228HD UHF/VHF antenna aimed at about , 350 degree magnetic compass direction.
______________
If required for better reception , install the CM7778 Preamp.
______________
A Winegard , DS3000 , J pole type antenna mount works well with CM4228HD antenna.
_______________
Here are some places to Buy antennas and etc. .
http://www.solidsignal.com.
http://www.amazon.com.
Digital tuners can develop -Digital Glitches- that are not cleared out with simple channel scans.
Do Double Rescan.
http://www.wchstv.com/DoubleRescanAlert.pdf.
It is also a good idea to rescan from time to time because New Digital BroadcastTv stations/channels can begin transmitting at any time with no notice.
______________________________
