Old 5-Jun-2011, 10:11 PM   #1
Stingerrray
Antenna Advice Possible Attic Install FL
Hi Guys, I am in need of a decent antenna. It is possible that I would install it in the Attic. Or in the back yard (although I would the prefer the attic). I am not versed in this at all. Any help would be appreciated greatly and a great time saver for me. Back yard is on the northern side of the house.
Thanks in advance,
Robert
http://www.tvfool.com/?option=com_wr...2193eb7b83c98c
Last edited by Stingerrray; 5-Jun-2011 at 10:16 PM. Reason: Add Back yard location
Stingerrray is offline   Reply With Quote
Old 5-Jun-2011, 10:23 PM   #2
How many Tv's will be connected??
Old 5-Jun-2011, 10:26 PM   #3
Stingerrray
2 Digital TV's
1 at first then 2 after I find that first one works OK.
Thanks,
'Robert
Old 5-Jun-2011, 11:27 PM   #4
The Digital broadcast television transmissions are strong at your location. One of these indoor antennas at each Tv will work fine , http://forum.tvfool.com/showthread.php?t=233 . Provided that the building is not wrapped with metal siding or a metal roof or poured concrete walls or brick from ground to roof. Here is how to point indoor Tv antennas , http://www.kyes.com/antenna/pointing/pointing.html , point the indoor Tv antenna at about 20 degree magnetic compass. . Or a Winegard Hd7694P antenna can be mounted in the attic and pointed at about 20 degree magnetic compass , the HD7694P will supply plenty of signal to 2 Tv's. Provided that the roof or walls are not made of metal. Here are some places to buy Tv antennas and etc.. , http://www.solidsignal.com , http://3starinc.com , http://www.starkelectronic.com , http://www.amazon.com
Old 6-Jun-2011, 4:20 AM   #5
Stingerrray
John C thanks just one more question
John thanks much for your help. I will go with the attic antenna. I would also like to add FM for my stereo. Should I just go with a little higher model of winegard that has FM??
Many Thanks,
Robert
Old 6-Jun-2011, 8:46 AM   #6
For FM radio reception it is best to use a separate FM antenna and separate coax. The Winegard HD6010 antenna is for local reception , and the HD6055P is a directional antenna for long distance FM radio reception.
