Old 18-Aug-2012, 9:00 PM   #1
densvxer
Question Mystified in Denver (New Antenna)
Im in Littleton colorado and trying to cut the cord. So I decided that if I can get at least the major networks OTA I'd cut the cord. I still cant get NBC
New antenna (winegard FV-HD30 FreeVision UHF VHF Antenna
) 13 miles from transmitter on lookout mountain 296 degrees nw, mounted on 5 foot mast on roof Should be No Sweat right? Not to be the case for me anyway.
my lng/lat is 39.627016,-105.037119
I still cant get NBC kusa channel 9 high vhf I can get channel 7 KMGH transmitted from the same tower. So i am just mystified and dont know what to try next.
Anybody have any ideas?
densvxer is offline   Reply With Quote
Old 18-Aug-2012, 9:03 PM   #2
densvxer
here's my channel listing map
Old 19-Aug-2012, 7:10 AM   #3
Tv Reception.
http://www.tvfool.com/?option=com_wr...9900fac7e660ae
Old 19-Aug-2012, 7:45 AM   #4
Tv Reception.
Strong signals and signal reflections , multi path.
Try a variable attenuator , # 1296F , to ' dial down ' the signal strength.
http://www.solidsignal.com.
Also can try a Winegard HD7210P directional antenna aimed at about 280 degree magnetic compass direction.
As always the starting antenna aim direction is --> the starting antenna aim direction.
The antenna can be turned to the left and right to find a direction that provides better reception.
Can also call the Tv station KUSA , chat with the engineering department and they can help.
Yes KUSA and KMGH both know about reception problems with VHF channels 9 and 7.
Old 19-Aug-2012, 4:25 PM   #5
densvxer
Thx for the input
What I found (didnt realize before) this morning was I had the antenna cable going through an input splitter for antenna, hdmi transmitter, dvr, dvd,,wireless video controller switch. When I bypassed this with the antenna cable and went direct, the auto program on my samsung went from 27 channels to 41 Great result including channel 9 I was about to add an old hd tuner that had a signal strength meter in it when I noticed, Since everything else uses a different input on the hdtv than coax There is no need for the ant coax to go through the switch Thx have a great sunday !!!
