Old 11-May-2011, 9:09 PM   #1
blackcat54
Question Help me choose an Antenna
I am looking for a side mount antenna mounted about 10-12' high.
http://www.tvfool.com/?option=com_wr...8d178bc1fa6532
How about an RCA HD751 (EZ HD)?
Ch 7 & 11 look to be Hi VHF
Ch 2, 4, 5, 9, 13, & 21 look to be UHF.
Thanks
blackcat54 is offline   Reply With Quote
Old 12-May-2011, 12:25 AM   #2
How many Tv's will be connected??
Old 12-May-2011, 1:49 AM   #3
blackcat54
One right now, maybe two down the road.
Old 12-May-2011, 2:10 AM   #4
Your location has many Tv stations that have strong transmissions all the way down to weak transmissions. For maximum reception of all the Tv stations in the direction of about 285 magnetic compass , I suggest a Winegard HD7082P all channel antenna. Here are places to buy Tv antennas and etc.. , http://www.solidsignal.com , http://www.3starinc.com , http://www.starkelectronic.com , http://www.amazon.com . Here is how to aim tv antennas , http://www.kyes.com/antenna/pointing/pointing.html
Old 12-May-2011, 6:29 AM   #5
blackcat54
The Winegard HD7082P is a beauty for sure, but I am looking for a side mount antenna. The Wingard needs a roof or chimney mount. I want to mount the antenna on the side of my house which is why I looked at the the RCA HD751.
Old 12-May-2011, 6:47 AM   #6
The RCA ANT-751 will do a fairly good job for you. It is not ideal if you want to reliably receive real channels 2 through 6. I suspect that real channel 4 (WPXO) will be OK due to the signal strength available, but real channels 2,3 and 6 further down the list may not be reliable.
I expect that most of the other stations in green and yellow on your TVFR will be received by the ANT-751.
Old 13-May-2011, 5:15 AM   #7
As all ways , Tv antennas receive the best when the Tv antenna has elbow room and nothing is blocking the front of the antenna or crowding in at the sides or back of the antenna.
